I have modified u-boot to change the MUX for specific pins (44 and 91), there are set as GPIO output open drain from board_early_init_f.
Then in board_late_init, I also set these GPIO using gpio-request and gpio_direction_output(xx, 1).
My issue is that between MUX setting and gpio_direction_output, the PDOR bit for these gpio is set to 0 (default boot value), so the pad is driven to 0 for a short time.
What is the proper way to fix that glich?
Should I change mux after I have used gpio_direction_output?
Should I change PDOR in board_early_init_f?
Is there another cleaner way to set PDOR bit as the same time the IOMUX register is set?
The glitch is around 100ms. On the GPIO there is a 10K pull-up to 3V3.
If I let the GPIO in high impedance, there is no glitch.
I will try to set the PDOR value before changing the IOMUX register but I’m not sure what I have to use to do it. Is clr/setbits_le32 the right functions to use, or should I use raw_read or direct memory access in C?
