Hi there,
I’m using the iMX6ULL with Linux Console, I’ve already enabled the spidev on device tree and now I’m trying to run the spidev_test.c example to verify my spidev device. I compiled the example using the arm-cross compiler “arm-linux-gnueabi-gcc”, but when I try tu run on iMX using “./outuput” on console, it returns to me:
root@colibri-imx6ull:~/test# ./output
-sh: ./output: not found
I’ve also try one hello-world code with no success. Do you know what I’m doing wrong here?
Thanks for your support!
Luccas
