Hello everyone,
I would like to rename additional network adapters on a custom carrier board on an apalis imx8qm module with Torizon OS so that they are more descriptive of the respective sockets.
How do I do that?
My udev rule always only used the ethernet0 interface. ![]()
A /etc/systemd/network/*.link entry with Match MACAddress or and Path= had no effect. ![]()
The network chips are soldered / connectet onto the board with the USB hubs on the module. They appear as eth0 … 2 in the system and work perfectly. Unfortunately, the names do not appear uniformly on all boards in relation to the sockets.
Best
Gerald
Software summary
Bootloader: U-Boot
Kernel version: 5.15.148-6.7.0-devel+git.f437ddb7191d #1-TorizonCore SMP PREEMPT Mon Jul 1 08:03:31 UTC 2024
Kernel command line: root=LABEL=otaroot rootfstype=ext4 quiet logo.nologo vt.global_cursor_default=0 plymouth.ignore-serial-consoles splash fbcon=map:3 ostree=/ostree/boot.1/torizon/0c2a7a82ae747ce050db101a71d4db0b7ea8d5c0d37c60af689476a0c166dc37/0
Distro name: NAME="TorizonCore"
Distro version: VERSION_ID=6.7.0-devel-20240701080203-build.0
Distro variant: VARIANT="Docker"
Hostname: apalis-imx8-07279040
Hardware info
HW model: Toradex Apalis iMX8QM V1.1 on Apalis Ixora V1.2 Carrier Board
Toradex version: 0037 V1.1E
Serial number: 07279040
Processor arch: aarch64
