Hi there.
We are building a custom TorizonOS image using the Yocto Project.
We need to use the /opt
directory in a specific recipe. However, when compiling, Bitbake presents some warnings notifying that it is not possible to use this type of directory (as discussed in the question: Torizon, changes to /opt folder).
Therefore, I would like to disable OSTree as I am not using OTA or offline updates in this project.
How can I do this without messing up my image generation?
Note: We tried to remove the meta-updater
from bblayers.conf but there are dependencies on this layer.
Settings:
Colibri iMX6DL 512MB V1.1A
Iris Carrier Board V1.1A
Base image: Torizon 6.5.0 (Kirkstone)
Greetings @jonathansilva,
I just want to understand your use-case here first. I have a couple of questions if you don’t mind answering:
What recipe here are you trying to add?
If you’re not using any kind of updates, and you’re doing a yocto build. Then for what reason are you using Torizon anymore? At that point could you not just use our reference BSP image that does not have any of this stuff in the first place? Or is there a reason you still want to use Torizon OS?
Hi @jeremias.tx,
My use case boils down to this situation: I’m migrating from Angstrom to Torizon because the applications that run on this system are being containerized. So, answering your questions:
I’m working in a project from the recipes-extended.
We are building bitbake on the common target torizon-core-docker
image. However, I just need something minimal with Docker compatibility and it must be a fully real-time image. Do you have any reference BSP image without OSTree and Aktualizr to recommend in this case?
Jonathan T.
I see. Well now my question is, would it be more work to modify/append this recipe you’re using to not use the /opt
directory anymore, or try and remove OSTree from our image. We have OSTree pretty heavily integrated on multiple levels of our image so it’s not the most trivial task to just remove it.
Or better yet what is this project you’re trying to add? Can it be added in another way rather than Yocto? Like in a container for instance.
To be clear how “real-time” are you thinking? Linux is not a true real-time OS if that is what you require, even with the real-time patch it is not considered true real-time.
We do not. So you still require Docker in this case then? Our BSP image does not have OSTree or Aktualizr, but it also does not have Docker.
