Dear Sir,
I have touchscreen FT5446 connected to the I2c2 and GPIO7 interrupt, gpio8 - reset and back ported kernel driver edt-ft5x06 for toradex 3.1.10 linux kernel. I have added touchscreen definition as bellow:
static struct edt_ft5x06_platform_data edt_ft5x06_pdata = {
.irq_pin = APALIS_GPIO7,
.reset_pin = APALIS_GPIO8,
static struct i2c_board_info apalis_t30_i2c_bus1_board_info[] __initdata = {
/* M41T0M6 real time clock on carrier board */
I2C_BOARD_INFO("rtc-ds1307", 0x68),
.type = "m41t00",
/* Touchscreen focaltech */
I2C_BOARD_INFO("edt-ft5x06", 0x38),
.platform_data = &edt_ft5x06_pdata,
additionally I have added device registration as bellow:
static struct platform_device apalis_t30_edt_ft5x06_device = {
.dev = {
.id = 543,
.name = "edt-ft5x06",
static void __init apalis_t30_i2c_init(void)
tegra_i2c_device1.dev.platform_data = &apalis_t30_i2c1_platform_data;
tegra_i2c_device3.dev.platform_data = &apalis_t30_i2c3_platform_data;
tegra_i2c_device4.dev.platform_data = &apalis_t30_i2c4_platform_data;
tegra_i2c_device5.dev.platform_data = &apalis_t30_i2c5_platform_data;
//tegra_i2c_device2.dev.platform_data = &apalis_t30_edt_ft5x06_device;
platform_device_register(&tegra_i2c_device1);
platform_device_register(&tegra_i2c_device3);
platform_device_register(&tegra_i2c_device4);
platform_device_register(&tegra_i2c_device5);
//platform_device_register(&tegra_i2c_device2);
platform_device_register(&apalis_t30_edt_ft5x06_device);
i2c_register_board_info(0, apalis_t30_i2c_bus1_board_info,
ARRAY_SIZE(apalis_t30_i2c_bus1_board_info));
/* enable touch interrupt GPIO */
gpio_request(TOUCH_PEN_INT, "TOUCH_PEN_INT");
gpio_direction_input(TOUCH_PEN_INT);
apalis_t30_i2c_bus5_board_info[1].irq = gpio_to_irq(TOUCH_PEN_INT);
i2c_register_board_info(4, apalis_t30_i2c_bus5_board_info,
ARRAY_SIZE(apalis_t30_i2c_bus5_board_info));
but still facing the error:
588:[ 10.797155] gpio_request: gpio-151 (edt-ft5x06 irq) status -16
589:[ 10.801551] edt_ft5x06 0-0038: Failed to request GPIO 151, error -16
command i2cdetect -y -r 0 is not detecting any devices. Can you tell me if my way, of registering device is correct, or if not how to do it correctly?
Best regards
Kamil
