WE have connected external RTC to 194 & 196 pin of iMX7D
WE are using Liux
How can we read hardware clock time from this RTC ?
I am getting below logs at boot time. …
[ 1.471093] rtc-ds1307: probe of 3-0068 failed with error -5
[ 1.479442] snvs_rtc 30370000.snvs:snvs-rtc-lp: rtc core: registered 30370000.snvs:snvs- as rtc1
[ 4.088602] hctosys: unable to open rtc device (rtc0)
and if run hwclock …
root@colibri-imx7:/# hwclock
hwclock: can’t open ‘/dev/misc/rtc’: No such file or directory
please suggest.
You need to add and configure proper driver for your RTC chip.
Hi Guys,
Thanks alex.tx for the comments.
But I got this solved by below steps:
my dmesg was giving me :
I referred the details on below link
from above link I tried to make rule file …
/etc/udev/rules.d/99-rtc1.rules
but this too did not work…
then at the same path … that is => /etc/udev/rules.d/
I found one more rule file => localextra.rules
in this file I changed the rule as below. commented line was previous… I changed to new one …
*# The first rtc device is symlinked to /dev/rtc
#KERNEL=="rtc0", SYMLINK+="rtc"
KERNEL=="rtc1", SYMLINK+="rtc"
and then my system started reading my RTC as hardware clock …
Neelam
Perfect, that your issue is solved. Thanks for the feedback.
