I am testing UART with the code in your website. I communicate with iMX6ULL through UART and send binary data over serial terminal. If the data is not an ordinary letter, it is not receiving it. For example, if there is 0x00 among the data, it can be read only before that. I have to receive all binary data and also send binary data.
The following is my code. Please let me know how to send and receive all binary data.
#include <stdio.h> /* I/O Definitions */
#include <unistd.h> /* Standard Symbolic Constants */
#include <fcntl.h> /* File Control Definitions */
#include <termios.h> /* POSIX Terminal Control Definitions */
#include <string.h> /* String Manipulation Definitions */
#include <errno.h> /* Error Code Definitions */
#include <stdlib.h>
typedef unsigned long u32;
typedef unsigned short u16;
typedef unsigned char u8;
#define BUFFER_SIZE 100
int main(int argc, char *argv[])
u8 buf_rx[BUFFER_SIZE];
u8 buf_tx[BUFFER_SIZE];
const char *device = "/dev/ttymxc1";
struct termios tty;
int fd, len;
int i=0;
int flags = O_RDWR | O_NOCTTY | O_NDELAY;
/*------------------------------- Opening the Serial Port -------------------------------*/
fd = open(device, flags);
if(fd == -1)
printf("\n Failed to open port! ");
return -1;
tcgetattr(fd, &tty); /* Get the current attributes of the Serial port */
cfsetispeed(&tty, B9600); /* Set read speed as 9600 baud */
cfsetospeed(&tty, B9600); /* Set write speed as 9600 baud */
tty.c_cflag &= ~PARENB; /* Disables the Parity Enable bit(PARENB) */
tty.c_cflag &= ~CSTOPB; /* Clear CSTOPB, configuring 1 stop bit */
tty.c_cflag &= ~CSIZE; /* Using mask to clear data size setting */
tty.c_cflag |= CS8; /* Set 8 data bits */
tty.c_cflag &= ~CRTSCTS; /* Disable Hardware Flow Control */
if((tcsetattr(fd, TCSANOW, &tty)) != 0)
/* Write the configuration to the termios structure*/
printf("Error! Can't set attributes.\n");
return -1;
else
printf("All set! \n");
tcflush(fd, TCIFLUSH);
memset(buf_rx, 0, BUFFER_SIZE);
while(1)
if(read(fd, buf_rx, sizeof(buf_rx)) != -1)
len = strlen(buf_rx);
#if 1
for(i=0; i<len; i++)
printf("%02X ", buf_rx[i]);
printf("\n");
#endif
if(buf_rx[0]==01)// && buf_rx[1]==0x01)
int send_len;
memset(buf_tx, 0, sizeof(buf_tx));
send_len = 4;
buf_tx[0]=0x01;
buf_tx[1] = 0x00;
buf_tx[2] = 0x03;
buf_tx[3] = 0x0D;
tcflush(fd, TCOFLUSH);
int result = write(fd, buf_tx, send_len);
if(result == -1)
printf("Error>>: %s\n",strerror(errno));
tcflush(fd, TCIOFLUSH);
usleep(1000);
close(fd);
If I send the following binary data, then read only ‘01’.
01 00 76 98 99 77 FF FF E6 6F 0D ==> Read only 01
01 01 76 98 99 77 FF FF E6 6F 0D ==> Read correctly.
02 00 76 98 99 77 FF FF E6 6F 0D ==> Read only 02
02 01 02 C8 1C 62 5B 01 95 CF 0D ==> Read correctly.
41 54 2B 43 43 4C 4B 3F 0D 0A ==> Read correctly.
