How to provide username and password for my registry in VSCode tcb-build task
My private repository has a username and password to pull images from it. How do I provide the username and password in my docker-compose.yml and tcbuild.yml files? Obviously I do not want to hard-code them into these files. The tcb-build task does not prompt me for a username and password. It just fails with a message when pulling my images: “Access forbidden”
Hello! Thank you for your question.
To securely provide the username and password required for your private repository when using TorizonCore Builder, you should avoid hard-coding sensitive information in your docker-compose.yml or tcbuild.yml files. Instead, use environment variables and authentication flags as follows:
For docker-compose.yml:
  • Store credentials in a .env file:
    Place a .env file in the same directory as your docker-compose.yml. Define your credentials in that file:
    REGISTRY_USERNAME=myuser
    REGISTRY_PASSWORD=mypassword
  • In your docker-compose.yml, reference these environment variables as needed.
    For example:
    environment:
      - USERNAME=${REGISTRY_USERNAME}
      - PASSWORD=${REGISTRY_PASSWORD}
More on this approach:
Setting environment variable before calling … docker-compose.yml
For TorizonCore Builder (tcbuild.yml):
  • Authenticate at runtime using the --login-to flag:
    The TorizonCore Builder requires you to log in to the registry before pulling or pushing images. Use the --login-to flag with your credentials when running TorizonCore Builder commands:
    torizoncore-builder platform push \
      --credentials <path-to-credentials.zip> \
      --login-to <registry-url> <username> <password> \
      --canonicalize \
      <path-to-dockercompose.yml>
  • Replace <registry-url>, <username>, and <password> with your actual registry information or use environment variables in your shell to keep credentials secure.
More on the process and security considerations:
Using Private Registries with the Torizon Platform
Note: For production, always follow security best practices when handling credentials.
Let me know if you need more details or a specific example!
Hi I am not trying to pull or push using torizoncore-builder. I am trying to build my OS and I need the credentials for the bundle step. I am using the tcb-build task. The torizoncore-builder “build” command does not accept a --login-to argument. Meanwhile, the tcb-build task does not ask for any credentials. So how do I bundle images from a private repository that requires a username and password?
I tried to add credentials to the task like so:
            "label": "tcb-build",
            "detail": "Build the tcbuild.yaml file and generate the custom image",
            "command": "DOCKER_HOST=",
            "type": "shell",
            "options": {
                "cwd": "${workspaceFolder}",
                "env": {
                    "VSCODE_CMD": "--verbose build",
                    "USERNAME": "${command:docker_login}",
                    "PASSWORD": "${command:docker_password}"
            "args": [
                "source",
                "./.conf/tcb-env-setup.sh",
                "-s",
                "${workspaceFolder}/storage",
                "-t",
                "${config:tcb.version}"
then in the tcbuild.yml file:
    bundle:
      compose-file: docker-compose.yml
      platform: linux/arm/v7
      registry: git.company.com:1234
      username: ${USERNAME}
      password: ${PASSWORD}
However the USERNAME and PASSWORD do not get set in the tcbuild.yml file. I get a warning that they are being defaulted to “”. How do I pass the username and password into the tcb-build task in VS Code?
Have you seen this article on private registries?
-Eric
Eric Singer
Toradex
Eric
Eric Singer
Toradex
Hi Eric,
Yes I read that article but it does not mention how to pass credentials to tcbuild.yml for building/bundling. When I use the “–set PASSWORD=mypass” build option I can pass variables in, but the password is echoed to the console when the command is run in VSCode. I edited the VSCode task and the set-env script so that nothing is echoed, and it is working now.
Thanks very much.
Jack
