By using the DSI to HDMI Adapter with there is a statement that HDMI (DVI-D) can be used via DSI.
If output is possible, please tell me if there is an easy way to display 1920x720 via the DSI to HDMI Adapter.
Hi @JCYoshihara,
Sorry for the delay in answering you.
For some reason, this topic got lost in the thread of messages…
If the whole point of your question is to change the system resolution to 1920x720, then it’s a matter of system configuration.
But that depends on which system are you using.
Could you provide more information about if your are using TorizonCore? Which Torizon?
Or Which Linux BSP?
André Curvello
