I tried to check if sound can be output from the headphones using the following command, but no sound was produced. Could you tell me what points I should check?
■ Steps Taken
root@imx95-a1-19x19-verdin:~/tmp# aplay -l
**** List of PLAYBACK Hardware Devices ****
card 1: btscoaudio [bt-sco-audio], device 0: sai-tx-rx-bt-sco-pcm-wb bt-sco-pcm-wb-0 [sai-tx-rx-bt-sco-pcm-wb bt-sco-pcm-wb-0]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 2: wm8904audio [wm8904-audio], device 0: HiFi wm8904-hifi-0 [HiFi wm8904-hifi-0]
Subdevices: 1/1
■ Direct Playback with aplay
root@imx95-a1-19x19-verdin:~/tmp# aplay -D hw:2,0 Alarm01.wav
Playing WAVE 'Alarm01.wav' : Signed 16 bit Little Endian, Rate 22050 Hz, Stereo
■ Result
No audio output.
■ Environment
i.MX95 Verdin EVK board by Tradex
