You suggest to configure DHCP server using systemd-networkd. (DHCP Server installation on Apalis TK1 with angstrom linux - Technical Support - Toradex Community)
I can not find where systemd-networkd configured with “[DHCPserver]” caches assigned IPs.
Does it have some place like dhcpd (/var/lib/dhcpd/dhcpd.leases) does? Help!
ОК! Is there a way to install dhcpd on toradex linux and work via dhcpd? Seems, it is not good idea to grep logs.
Yes, you can install the dhcp-server.
opkg update listopkg install dhcp-server
Best regards
Thank U very much!
You are welcome.
