I have created my customized .dtb file and then copies to the boot section of the image. how does imx6 will understand which .dtb file to take ?
Hi @lokeshbathala
Please have a look here.
when i used that is described in the link
Apalis iMX6 # setenv fdt_board eval-shutdown
Apalis iMX6 # saveenv
Saving Environment to MMC…
Env export buffer too small: 8188, but need 8542
ERROR: Cannot export environment: errno = 12
at /home/skanray/oe-core/build/tmp-glibc/work/apalis_imx6-angstrom-linux-gnueabi/u-boot-toradex/2016.11-2.7.5+gitrAUTOINC+52259cf22a/git/common/env_common.c:239/env_export()
Hi jaski,
what is this error mean ? how to avoid this ?
Could you provide the version of your hardware and software?
You should update first to regular Bsp release and then copy the customize dtb file to the module.
v1.1 image version apalis-lxde-image 2.7.2
Please provide the output of uname -r?
