I’m attaching a “Resistive Touch Display 7” on connector X34.
How can a determine the correct interface name for use in weston.ini file in the output ?
Greetings @bkennis,
To figure out the display interface names to use in Weston you can check the contents of /sys/class/drm
. For example you would see something like this:
ls /sys/class/drm
card0 card1 card1-HDMI-A-1 card1-LVDS-1 renderD128 renderD129 version
In this example the relevant interface names would be HDMI-A-1
or LVDS-1
. You shouldn’t need the card1-*
part of the name. If I remember correctly for parallel RGB displays like the resistive touch display, the interface name should be something like DPI-1
or similar. Make sure to check the exact name for yourself on your system to be sure.
