Hi @ToradexAI
Here is my configuration:
torizon@verdin-imx8mp-15229850:~$ sudo tdx-info
Password:
Software summary
Bootloader: U-Boot
Kernel version: 5.15.148-6.6.1+git.23a8e831749d #1-TorizonCore SMP PREEMPT Thu Feb 29 20:25:21 UTC 2024
Kernel command line: root=LABEL=otaroot rootfstype=ext4 quiet logo.nologo vt.global_cursor_default=0 plymouth.ignore-serial-consoles splash fbcon=map:3 ostree=/ostree/boot.1/torizon/f5f0b9e40c1595ab904ce493a792a0b54e17f0dc3ce6832ddb889452bdd13704/0
Distro name: NAME="TorizonCore"
Distro version: VERSION_ID=6.6.1-build.14
Distro variant: VARIANT="Docker"
Hostname: verdin-imx8mp-15229850
Hardware info
Toradex version: 0058 V1.1B
Serial number: 15229850
Processor arch: aarch64
Here is my evaluation kit version:
[Hardware Configuration]
Verdin iMX8M Plus Evaluation Kit with Touchscreen
with:
SOM i.MX8M Plus Quad 4GB WB IT v1.1B
Dahlia Carrier Board v1.1D
Verdin DSI to LVDS rev 1.1A
Capacitive Touch Display 10.1" v1.0A
I use the Torizon IDE extension version v2.5.171 (pre-release) and VS Code 1.90.2 on my Windows 11 Business 23H2.
The problem I am facing is that I fail to launch my application in release mode.
Here are the logs of what I have on my target device, and what I am doing to start my application:
torizon@verdin-imx8mp-15229850:~$ ls -al
total 40
drwxr-xr-x 4 torizon torizon 4096 Jul 3 14:14 .
drwxr-xr-x 4 root root 4096 Jan 1 1970 ..
-rw------- 1 torizon torizon 6310 Jun 26 14:36 .bash_history
-rwxr-xr-x 1 torizon torizon 286 Jan 1 1970 .bashrc
drwx------ 3 torizon torizon 4096 Jun 20 12:57 .config
drwx------ 3 torizon torizon 4096 Jul 3 14:14 .docker
-rw-r--r-- 1 torizon torizon 79 Jul 3 14:14 .env
-rwxr-xr-x 1 torizon torizon 241 Jan 1 1970 .profile
-rw-r--r-- 1 torizon torizon 1916 Jul 3 14:32 docker-compose.yml
torizon@verdin-imx8mp-15229850:~$ cat .env
LOCAL_REGISTRY=192.168.10.112
DOCKER_LOGIN=192.168.10.112
TAG=arm64
GPU=-imx8
torizon@verdin-imx8mp-15229850:~$ cat docker-compose.yml
version: "3.9"
services:
avalonia-gtk-mvvm-debug:
build:
context: .
dockerfile: Dockerfile.debug
image: ${LOCAL_REGISTRY}:5002/avalonia-gtk-mvvm:${TAG}
ports:
- 2223:2223
volumes:
- type: bind
source: /tmp
target: /tmp
- type: bind
source: /dev
target: /dev
device_cgroup_rules:
# ... for tty0
- "c 4:0 rmw"
# ... for tty7
- "c 4:7 rmw"
# ... for /dev/input devices
- "c 13:* rmw"
- "c 199:* rmw"
# ... for /dev/dri devices
- "c 226:* rmw"
depends_on: [
weston
avalonia-gtk-mvvm:
build:
context: .
image: ${DOCKER_LOGIN}/avalonia-gtk-mvvm:${TAG}
volumes:
- type: bind
source: /tmp
target: /tmp
- type: bind
source: /dev
target: /dev
# ... for tty0
- "c 4:0 rmw"
# ... for tty7
- "c 4:7 rmw"
- "c 13:* rmw"
- "c 199:* rmw"
- "c 226:* rmw"
depends_on: [
weston
weston:
image: commontorizon/weston${GPU}:next
environment:
- ACCEPT_FSL_EULA=1
# Required to get udev events from host udevd via netlink
network_mode: host
volumes:
- type: bind
source: /tmp
target: /tmp
- type: bind
source: /dev
target: /dev
- type: bind
source: /run/udev
target: /run/udev
cap_add:
- CAP_SYS_TTY_CONFIG
# Add device access rights through cgroup...
# ... for tty0
- "c 4:0 rmw"
# ... for tty1
- "c 4:1 rmw"
# ... for tty7
- "c 4:7 rmw"
- "c 13:* rmw"
- "c 199:* rmw"
- "c 226:* rmw"
torizon@verdin-imx8mp-15229850:~$ docker image ls
REPOSITORY TAG IMAGE ID CREATED SIZE
192.168.10.112:5002/avalonia-gtk-mvvm arm64 eac4b55e159d 53 minutes ago 811MB
commontorizon/weston-imx8 next 83f43412224c 3 weeks ago 511MB
nodered/node-red 3.1.3 12234ad916b0 5 months ago 564MB
torizon@verdin-imx8mp-15229850:~$ docker ps -a
torizon@verdin-imx8mp-15229850:~$ docker-compose up -d
[+] Running 1/1
! avalonia-gtk-mvvm Warning 15.0s
[+] Building 0.1s (1/2) docker:default
=> [avalonia-gtk-mvvm internal] load build definition from Dockerfile 0.0s
=> => transferring dockerfile: 2B 0.0s
failed to solve: failed to solve with frontend dockerfile.v0: failed to read dockerfile: open /var/lib/docker/tmp/buildkit-mount2310827459/Dockerfile: no such file or directory
When I try to start my application issuing the docker-compose up -d, it fails with the message:
But, when I click on the task , I have the following logs in the terminal of VS Code, and the application is running correctly on my board and the display of the GUI on my touchscreen is correct aslo.
=============> ] 22.94MB/30.81MB
849fdfa11c07 Extracting [======================================> ] 23.92MB/30.81MB
849fdfa11c07 Extracting [========================================> ] 24.9MB/30.81MB
849fdfa11c07 Extracting [==========================================> ] 25.89MB/30.81MB
849fdfa11c07 Extracting [===========================================> ] 26.87MB/30.81MB
849fdfa11c07 Extracting [=============================================> ] 27.85MB/30.81MB
849fdfa11c07 Extracting [==============================================> ] 28.84MB/30.81MB
849fdfa11c07 Extracting [================================================> ] 29.82MB/30.81MB
849fdfa11c07 Extracting [=================================================> ] 30.8MB/30.81MB
849fdfa11c07 Extracting [==================================================>] 30.81MB/30.81MB
849fdfa11c07 Pull complete
11d7b786b094 Extracting [==================================================>] 347B/347B
11d7b786b094 Pull complete
b4e35910b6a0 Extracting [=> ] 32.77kB/1.011MB
b4e35910b6a0 Extracting [===> ] 65.54kB/1.011MB
b4e35910b6a0 Extracting [=========================> ] 524.3kB/1.011MB
b4e35910b6a0 Extracting [===========================================> ] 884.7kB/1.011MB
b4e35910b6a0 Extracting [==================================================>] 1.011MB/1.011MB
b4e35910b6a0 Pull complete
0502f956be65 Extracting [> ] 524.3kB/50.2MB
0502f956be65 Extracting [=> ] 1.573MB/50.2MB
0502f956be65 Extracting [==> ] 2.621MB/50.2MB
0502f956be65 Extracting [===> ] 3.146MB/50.2MB
0502f956be65 Extracting [====> ] 4.194MB/50.2MB
0502f956be65 Extracting [=====> ] 5.243MB/50.2MB
0502f956be65 Extracting [======> ] 6.291MB/50.2MB
0502f956be65 Extracting [=======> ] 7.34MB/50.2MB
0502f956be65 Extracting [========> ] 8.389MB/50.2MB
0502f956be65 Extracting [=========> ] 9.437MB/50.2MB
0502f956be65 Extracting [==========> ] 10.49MB/50.2MB
0502f956be65 Extracting [===========> ] 11.53MB/50.2MB
0502f956be65 Extracting [============> ] 12.58MB/50.2MB
0502f956be65 Extracting [=============> ] 13.63MB/50.2MB
0502f956be65 Extracting [==============> ] 14.68MB/50.2MB
0502f956be65 Extracting [===============> ] 15.73MB/50.2MB
0502f956be65 Extracting [================> ] 16.78MB/50.2MB
0502f956be65 Extracting [=================> ] 17.83MB/50.2MB
0502f956be65 Extracting [==================> ] 18.87MB/50.2MB
0502f956be65 Extracting [===================> ] 19.92MB/50.2MB
0502f956be65 Extracting [====================> ] 20.97MB/50.2MB
0502f956be65 Extracting [=====================> ] 22.02MB/50.2MB
0502f956be65 Extracting [======================> ] 23.07MB/50.2MB
0502f956be65 Extracting [========================> ] 24.12MB/50.2MB
0502f956be65 Extracting [=========================> ] 25.17MB/50.2MB
0502f956be65 Extracting [==========================> ] 26.21MB/50.2MB
0502f956be65 Extracting [===========================> ] 27.26MB/50.2MB
0502f956be65 Extracting [============================> ] 28.31MB/50.2MB
0502f956be65 Extracting [=============================> ] 29.36MB/50.2MB
0502f956be65 Extracting [==============================> ] 30.41MB/50.2MB
0502f956be65 Extracting [===============================> ] 31.46MB/50.2MB
0502f956be65 Extracting [================================> ] 32.51MB/50.2MB
0502f956be65 Extracting [=================================> ] 33.55MB/50.2MB
0502f956be65 Extracting [==================================> ] 34.6MB/50.2MB
0502f956be65 Extracting [===================================> ] 35.65MB/50.2MB
0502f956be65 Extracting [====================================> ] 36.7MB/50.2MB
0502f956be65 Extracting [=====================================> ] 37.75MB/50.2MB
0502f956be65 Extracting [======================================> ] 38.8MB/50.2MB
0502f956be65 Extracting [=======================================> ] 39.32MB/50.2MB
0502f956be65 Extracting [=======================================> ] 39.85MB/50.2MB
0502f956be65 Extracting [========================================> ] 40.89MB/50.2MB
0502f956be65 Extracting [=========================================> ] 41.94MB/50.2MB
0502f956be65 Extracting [==========================================> ] 42.47MB/50.2MB
0502f956be65 Extracting [==========================================> ] 42.99MB/50.2MB
0502f956be65 Extracting [===========================================> ] 44.04MB/50.2MB
0502f956be65 Extracting [============================================> ] 45.09MB/50.2MB
0502f956be65 Extracting [=============================================> ] 45.61MB/50.2MB
0502f956be65 Extracting [=============================================> ] 46.14MB/50.2MB
0502f956be65 Extracting [==============================================> ] 46.66MB/50.2MB
0502f956be65 Extracting [==============================================> ] 47.19MB/50.2MB
0502f956be65 Extracting [================================================> ] 48.23MB/50.2MB
0502f956be65 Extracting [================================================> ] 48.76MB/50.2MB
0502f956be65 Extracting [=================================================> ] 49.28MB/50.2MB
0502f956be65 Extracting [=================================================> ] 49.81MB/50.2MB
0502f956be65 Extracting [==================================================>] 50.2MB/50.2MB
0502f956be65 Pull complete
96d2f4b00c37 Extracting [==================================================>] 268B/268B
96d2f4b00c37 Pull complete
80571161145d Extracting [> ] 131.1kB/10.46MB
80571161145d Extracting [=====> ] 1.049MB/10.46MB
80571161145d Extracting [==========> ] 2.097MB/10.46MB
80571161145d Extracting [==============> ] 3.015MB/10.46MB
80571161145d Extracting [==================> ] 3.801MB/10.46MB
80571161145d Extracting [======================> ] 4.719MB/10.46MB
80571161145d Extracting [==========================> ] 5.636MB/10.46MB
80571161145d Extracting [===============================> ] 6.554MB/10.46MB
80571161145d Extracting [===================================> ] 7.471MB/10.46MB
80571161145d Extracting [========================================> ] 8.389MB/10.46MB
80571161145d Extracting [=============================================> ] 9.437MB/10.46MB
80571161145d Extracting [=================================================> ] 10.35MB/10.46MB
80571161145d Extracting [==================================================>] 10.46MB/10.46MB
80571161145d Pull complete
4f4fb700ef54 Extracting [==================================================>] 32B/32B
4f4fb700ef54 Pull complete
avalonia-gtk-mvvm Pulled
* Terminal will be reused by tasks, press any key to close it.
* Executing task: DOCKER_HOST=192.168.10.111:2375 DOCKER_LOGIN=192.168.10.112:5002 TAG=arm64 GPU=-imx8 docker compose -p torizon up avalonia-gtk-mvvm
WARN[0000] The "LOCAL_REGISTRY" variable is not set. Defaulting to a blank string.
WARN[0000] /home/torizon/dev/AvaloniaGTKMVVM/docker-compose.yml: `version` is obsolete
[+] Running 3/2
✔ Network torizon_default Created 0.1s
✔ Container torizon-weston-1 Created 4.2s
✔ Container torizon-avalonia-gtk-mvvm-1 Created 0.1s
Attaching to avalonia-gtk-mvvm-1
avalonia-gtk-mvvm-1 | EGL: Warning: No default display support on wayland
avalonia-gtk-mvvm-1 | Hello Torizon!
192.168.10.112:5002/avalonia-gtk-mvvm <none> eac4b55e159d About an hour ago 811MB
192.168.10.112:5002/avalonia-gtk-mvvm arm64 08f84ae4f925 7 hours ago 588MB
67a444b1f983 192.168.10.112:5002/avalonia-gtk-mvvm:arm64 "./AvaloniaGTKMVVM" 2 minutes ago Up 2 minutes torizon-avalonia-gtk-mvvm-1
dc42507e7b1e commontorizon/weston-imx8:next "/usr/bin/entry.sh" 2 minutes ago Up 2 minutes (healthy) torizon-weston-1
So, I wonder what is incorrect in my workflow for launching my application using the command docker-compose up -d, since the images are already on the target device and the docker-compose.yml and the .env files are in same the directory where I issue the command docker-compose up -d command.
Could you please help me on this topic ?
Thank you.
Sincerely,
François.
