Could you provide the version of the Software of your module? Which carrier board are you using?
How to upgrade to Java 8?
You have to create a custom image with including your preferred version of Java.
How to install manually or automatically, VoIP SIP (Java OSGi) client in Yoсto?
You need to check if the client is available on OpenEmbedded. If it is available, then you can include this in your image. If not, then please have a look here.
The Jitsi told me that they had no development experience in Yokto.
I have colibri-imx-emmc 4.9.87-2.8.4+g3bb6e32 (Java 7).
I have a ready-made image. The device comes standard with the installed image. I can only add.
I have a very limited set of commands. How to install the clone command and others?
How to install commands to my image?
Thanks.
