I need to install NTP server on colibri T20 machine. While installing this package using apt-get install
- “apt-get install ntp”
it shows the following error,
“Command not found - apt-get”
How to install ntp on colibri T20 machine?
What exact hardware and software versions of things are you talking about?
Colibri T20 512MB v1.2a
And the software?
software version - Colibri-T20_Qt5-X11-Image_2.7.5
Thanks for your answer.
You can install ntp using the following commands:
opkg update listopkg install ntpBest regards, Jaski
Thank you very much. it is working.
Perfect. Thanks for the feedback.
