i have install the linux demo image using TEZI installer first time from network and it is working fine on my board.
now i want to install through offline using USB flash drive.
Steps i followed :
Downloaded the Tezi installer and linux demo image.
untar and copy the image in usb pen drive.
insert the USB into board .
gone to recovery mode .
getting the TEZI installer Page on desktop.
but the installer can’t able to find out the image.
continuously looping on waiting for external media or network.
Please guide.
Somnath Roy
Welcome to minicom 2.7
OPTIONS: I18n
Compiled on Feb 7 2016, 13:37:27.
Port /dev/ttyUSB0, 21:31:04
Press CTRL-A Z for help on special keys
U-Boot 2016.11-2.8.2+g087e95a (Mar 31 2018 - 06:11:19 +0000)
CPU: Freescale i.MX6ULL rev1.0 792 MHz (running at 396 MHz)
CPU: Industrial temperature grade (-40C to 105C) at 29C
Reset cause: POR
DRAM: 512 MiB
NAND: 512 MiB
MMC: FSL_SDHC: 0
Video: 640x480x18
In: serial
Out: serial
Err: serial
Model: Toradex Colibri iMX6ULL 512MB Wi-Fi / Bluetooth IT V1.0A, Serial# 03073121
Net: FEC0
Colibri iMX6ULL # bmode usb
resetting ...
U-Boot 2016.11-1.5.0+g087e95a (May 07 2018 - 12:58:24 +0000)
CPU: Industrial temperature grade (-40C to 105C) at 36C
Reset cause: WDOG
DRAM: 512 MiB
NAND: 512 MiB
MMC: FSL_SDHC: 0
Using default environment
Video: 640x480x18
In: serial
Out: serial
Err: serial
Serial Downloader recovery mode, using sdp command
Net: FEC0
SDP: initialize...
SDP: handle requests...
Downloading file of size 20851764 to 0x82100000... done
Downloading file of size 244 to 0x82000000... done
Jumping to header at 0x82000000
Header Tag is not a IMX image
## Loading kernel from FIT Image at 82100000 ...
Using 'config@1' configuration
Trying 'kernel@1' kernel subimage
Description: Linux Kernel 4.1
Type: Kernel Image
Compression: uncompressed
Data Start: 0x821000e0
Data Size: 4887216 Bytes = 4.7 MiB
Architecture: ARM
OS: Linux
Load Address: 0x81000000
Entry Point: 0x81000000
Hash algo: md5
Hash value: 7d82f4adc5f0b06b3095a85f284fee53
Verifying Hash Integrity ... md5+ OK
## Loading ramdisk from FIT Image at 82100000 ...
Trying 'ramdisk@1' ramdisk subimage
Description: SquashFS RAMdisk
Type: RAMDisk Image
Data Start: 0x825a9478
Data Size: 15925248 Bytes = 15.2 MiB
Architecture: ARM
OS: Linux
Load Address: unavailable
Entry Point: unavailable
Hash algo: md5
Hash value: d02ecdfe283960e26ec2dd8844bc8b91
## Loading fdt from FIT Image at 82100000 ...
Trying 'fdt@1' fdt subimage
Description: Colibri iMX6ULL Device Tree
Type: Flat Device Tree
Data Start: 0x834d9544
Data Size: 37816 Bytes = 36.9 KiB
Architecture: ARM
Hash algo: md5
Hash value: f61ffa470f6c279d7fade885b5600b74
Booting using the fdt blob at 0x834d9544
Loading Kernel Image ... OK
Loading Device Tree to 8fff3000, end 8ffff3b7 ... OK
Updating MTD partitions...
Starting kernel ...
[ 0.540706] gpmi-nand 1806000.gpmi-nand: mode:5 ,failed in set feature.
[ 0.588049] imx_usb 2184000.usb: Can't register ci_hdrc platform device, err=-517
[ 0.748435] rtc-ds1307 0-0068: hctosys: unable to read the hardware clock
Running /etc/rc.local...
Colibri-iMX6ULL_ToradexEasyInstaller_1.5-20180507
Welcome to Toradex Easy Installer
This is a Linux based installer for Toradex modules. Currently the
installer does not have a serial console interface. You can use the
Toradex Easy Installer through any of the available display interfaces
using USB mouse/keyboard or via network using VNC. Use:
# ip addr show eth0
to display the Ethernet IP address or use USB RNDIS at IP 192.168.11.1.
