In our carrierboard we have an application running on WEC7 / Colibri iMX6DL, this application requires two fonts that are not installed in the BSP (Symbol.ttf and Wingding.ttf).
A requirement of our device is that the explorer.exe is disabled by default
To solve the issue of missing fonts we use the EarlyAutoCopy tool to copy them to the windows folder every time the device starts. This works only with the explorer active, if you disabled it, the fonts are never copied.
Another possible solution that we tried was to change the fontpath in the windows registry to \ FlashDisk \ fonts so that you do not have to copy the files with each reboot but in the same way it only works with the explorer active
Do you have any idea how we could solve our problem?
Best regards
