I want to handle signal (ctrl+c) in wince 7.But unfortunately signal.h header file is missing in the Wince SDK path.Can you please suggest something??
Shantanu K. Pradhan
Shantanu K. Pradhan
Did you already checked this website: winapi - How can I handle Ctrl+C in a Windows CE console application? - Stack Overflow?
Hi Samuel,
i have already checked the link you provided but they have given the solution by assuming that we have console.h header file.But i checked in Wince SDK installation folder but it does not have the console.h header file.
Shantanu K. Pradhan
One way would be to use IOCTL_CONSOLE_SETCONTROLCEVENT. As the console.h file is missing from the SDK, you could manually add the missing defines:
#include <winioctl.h>
#define IOCTL_CONSOLE_SETCONTROLCEVENT CTL_CODE(FILE_DEVICE_CONSOLE, 10, METHOD_BUFFERED, FILE_ANY_ACCESS)
After that you should be able to call the DeviceIoCTL as described on MSDN. This only applies on consoles. Not sure if this does actually what you want.
Hi Samuel,
Thanks for your response.This is what i tested/implemented as you told and its working for me…
////#include "stdafx.h"
#include
#include
#include
#include
HANDLE ghWriteEvent;
HANDLE ghThreads;
void CreateEventsAndThreads(void) ;
DWORD WINAPI ThreadProc(LPVOID lpParam) ;
int FLAG=1;
int main( void )
// DWORD dwWaitResult;
BOOL bSuccess;
DWORD dwRead = 0;
DWORD dwActualOut=0;
CreateEventsAndThreads();
bSuccess = DeviceIoControl(_fileno(stdout), IOCTL_CONSOLE_SETCONTROLCEVENT, &ghWriteEvent, sizeof(HANDLE), &dwRead, sizeof(DWORD), & dwActualOut, NULL);
if(bSuccess==0)
printf("Device controll failed!!!!\n");
while(FLAG)
Sleep(1000);
printf("Hello i'm in while loop\n");
//int i;
DWORD dwThreadID;
//ghWriteEvent = CreateEvent(
// NULL, // default security attributes
// TRUE, // manual-reset event
// FALSE, // initial state is nonsignaled
// TEXT("WriteEvent") // object name
ghWriteEvent=CreateEvent( NULL, TRUE, FALSE, NULL );
if (ghWriteEvent == NULL)
printf("CreateEvent failed (%d)\n", GetLastError());
return;
ghThreads = CreateThread(
0, // default stack size
ThreadProc, // name of the thread function
NULL, // no thread parameters
0, // default startup flags
&dwThreadID);
if (ghThreads == NULL)
printf("CreateThread failed (%d)\n", GetLastError());
return;
DWORD dwWaitResult;
printf("Thread %d waiting for write event...\n", GetCurrentThreadId());
dwWaitResult = WaitForSingleObject(
ghWriteEvent, // event handle
INFINITE); // indefinite wait
FLAG = 0;
printf("Exit\n");
Thanks again…
Shantanu K. Pradhan
