I just received the Dahlia Carrier board with Verdin iMX8M Plus.
I build Linux image using Yocto.
How can I flash my build image to carrier board.
Thanks!
Thanks!
The Verdin iMX8M Plus comes with Toradex Easy Installer pre-installed (1). Once you power-on the board, it will display a list of available images to be installed (1).
To flash your custom Yocto image to the Verdin iMX8M Plus on the Dahlia Carrier Board:
For detailed step-by-step instructions on how to get started with flashing your image, you can follow the Verdin iMX8M Plus step-by-step Quickstart guide (1).
The process involves using the Toradex Easy Installer - Getting Started guide (1), which will walk you through the complete flashing procedure for your custom Yocto-built image.
The Dahlia Carrier Board provides convenient USB-C connectivity for powering and communication during the flashing process (2).
Kevin,
Could you please share your resulting xz tarbal using our share server share.toradex.com
Alexander Samutin
Toradex
Hi @kevinxzl ,
Once you use the shareable link can you share with us via email? support.na@toradex.com.
