I am following the Toradex OpenEmbedded (core) build instructions (here) but I am running into trouble in the do_image.wic step due to Docker not implementing the FIGETBSZ ioctl for its file system.
After searching, I have found that there have been patches made to correct these problems:
- Making sure you're not a bot!
- BmapHelpers.py: fix [Errno 25] Inappropriate ioctl for device (#30) · intel/bmap-tools@0a567e4 · GitHub
What is the best way to apply these patches so that I can complete the build in Docker? Does Toradex already have an alternative method to build in Docker?
Thanks for your help!
