Hello! I am using multiple wakeup sources in my device tree: RTC interrupt (pin 45), button (pin 55) and accelerometer interrupt (pin 30). All interrupts wakeup the SoM as expected.
How can I find the interrupt source after the SoM wakes up from standby/suspend? (In other words, how can I find which interrupt was the reason for the system wakeup)
Colibri iMX6ULL 512MB WB IT
Custom carrier board
Linux TDX X11 5.2.0-devel-20210226152038+build.0 (dunfell)
Hello @CristianM ,
This information should be available from cat /var/log/syslog . Could you please check there once?
Janani
@saijanani.tx I have checked, but I get: cat: /var/log/syslog: No such file or directory. Currently, I can find out the interrupt source by comparing the number of interrupts for each wakeup source using cat /proc/interrupts, but it is not the most elegant solution.
Hello @CristianM ,
You could install rsyslog to your image. Alternatively, you can use the journalctl or even dmesg log for this purpose. Could you maybe try those?
BR, Janani
@saijanani.tx dmesg does not show the wakeup source, as you can see:
[ 121.280617] PM: suspend entry (deep)
[ 121.305795] Filesystems sync: 0.025 seconds
[ 121.374445] Freezing user space processes ... (elapsed 0.004 seconds) done.
[ 121.378678] OOM killer disabled.
[ 121.378689] Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
[ 121.385920] mwifiex_sdio mmc1:0001:1: info: successfully disconnected from 28:ee:52:33:87:70: reason code 3
[ 121.389641] mwifiex_sdio mmc1:0001:1: None of the WOWLAN triggers enabled
[ 121.494737] PM: suspend devices took 0.110 seconds
[ 121.498847] Disabling non-boot CPUs ...
[ 122.012407] PM: resume devices took 0.510 seconds
[ 122.012427] OOM killer enabled.
[ 122.012434] Restarting tasks ... done.
[ 122.041600] PM: suspend exit
[ 122.230489] mwifiex_sdio mmc1:0001:1: info: trying to associate to 'netis' bssid 28:ee:52:33:87:6f
[ 122.414100] mwifiex_sdio mmc1:0001:1: info: associated to bssid 28:ee:52:33:87:6f successfully
Also, journalctl does not show the wakeup source:
Oct 15 09:37:41 magus-dl kernel[169]: [ 121.280617] PM: suspend entry (deep)
Oct 15 09:37:41 magus-dl kernel: Filesystems sync: 0.025 seconds
Oct 15 09:37:41 magus-dl kernel[169]: [ 121.305795] Filesystems sync: 0.025 seconds
Oct 15 09:37:45 magus-dl kernel: Freezing user space processes ... (elapsed 0.004 seconds) done.
Oct 15 09:37:45 magus-dl kernel: OOM killer disabled.
Oct 15 09:37:45 magus-dl kernel: Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
Oct 15 09:37:45 magus-dl kernel: mwifiex_sdio mmc1:0001:1: info: successfully disconnected from 28:ee:52:33:87:70: reason code 3
Oct 15 09:37:45 magus-dl kernel: mwifiex_sdio mmc1:0001:1: None of the WOWLAN triggers enabled
Oct 15 09:37:45 magus-dl kernel: PM: suspend devices took 0.110 seconds
Oct 15 09:37:45 magus-dl kernel: Disabling non-boot CPUs ...
Oct 15 09:37:45 magus-dl kernel: PM: resume devices took 0.510 seconds
Oct 15 09:37:45 magus-dl kernel: OOM killer enabled.
Oct 15 09:37:45 magus-dl kernel: Restarting tasks ... done.
Oct 15 09:37:45 magus-dl kernel: PM: suspend exit
Oct 15 09:37:45 magus-dl wpa_supplicant[479]: mlan0: CTRL-EVENT-DISCONNECTED bssid=28:ee:52:33:87:70 reason=3 locally_generated=1
Oct 15 09:37:45 magus-dl wpa_supplicant[479]: dbus: wpa_dbus_property_changed: no property SessionLength in object /fi/w1/wpa_supplicant1/Interfaces/1
Oct 15 09:37:45 magus-dl kernel[169]: [ 121.374445] Freezing user space processes ... (elapsed 0.004 seconds) done.
Oct 15 09:37:45 magus-dl NetworkManager[417]: <warn> [1634290665.3520] sup-iface[0x1e66b78,mlan0]: connection disconnected (reason -3)
Oct 15 09:37:45 magus-dl kernel[169]: [ 121.378678] OOM killer disabled.
Oct 15 09:37:45 magus-dl NetworkManager[417]: <info> [1634290665.3702] device (mlan0): supplicant interface state: completed -> disconnected
Oct 15 09:37:45 magus-dl kernel[169]: [ 121.378689] Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
Oct 15 09:37:45 magus-dl kernel[169]: [ 121.385920] mwifiex_sdio mmc1:0001:1: info: successfully disconnected from 28:ee:52:33:87:70: reason code 3
Oct 15 09:37:45 magus-dl kernel[169]: [ 121.389641] mwifiex_sdio mmc1:0001:1: None of the WOWLAN triggers enabled
Oct 15 09:37:45 magus-dl kernel[169]: [ 121.494737] PM: suspend devices took 0.110 seconds
Oct 15 09:37:45 magus-dl kernel[169]: [ 121.498847] Disabling non-boot CPUs ...
Oct 15 09:37:45 magus-dl kernel[169]: [ 122.012407] PM: resume devices took 0.510 seconds
Oct 15 09:37:45 magus-dl kernel[169]: [ 122.012427] OOM killer enabled.
Oct 15 09:37:45 magus-dl kernel[169]: [ 122.012434] Restarting tasks ... done.
Oct 15 09:37:45 magus-dl kernel[169]: [ 122.041600] PM: suspend exit
Oct 15 09:37:45 magus-dl NetworkManager[417]: <info> [1634290665.4618] device (mlan0): supplicant interface state: disconnected -> scanning
Oct 15 09:37:45 magus-dl wpa_supplicant[479]: mlan0: Trying to associate with 28:ee:52:33:87:6f (SSID='netis' freq=5180 MHz)
Oct 15 09:37:45 magus-dl kernel: mwifiex_sdio mmc1:0001:1: info: trying to associate to 'netis' bssid 28:ee:52:33:87:6f
rsyslog may be a solution, but I haven’t tried it. It takes some time to recompile the image and flash the device again. However, I think rsyslog logs the same messages presented above.
Hello @CristianM ,
After digging around a bit and asking around, I have been told that some files in /sys/power could do the trick e.g: pm_wakeup_irq
The following thread from NXP also tackles the issue. This may be helpful as well.
Janani
@saijanani.tx Thank you. It helped. With cat /sys/power/pm_wakeup_irq I can get the IRQ number that triggered the wakeup and I can match it in cat /proc/interrupts.
