I am modifying the default devicetree using an overlay. I want to enable three CS on spidev.
devicetree:
&pinctrl_ecspi1_cs{
fsl,pins = <
MX6UL_PAD_LCD_DATA21__GPIO3_IO26 0x000a0
MX6UL_PAD_LCD_DATA05__GPIO3_IO10 0x000a0
MX6UL_PAD_LCD_DATA06__GPIO3_IO11 0x000a0
&ecspi1 {
fsl,spi-num-chipselects = <3>;
cs-gpios =
<&gpio3 26 GPIO_ACTIVE_HIGH>,
<&gpio3 10 GPIO_ACTIVE_HIGH>,
<&gpio3 11 GPIO_ACTIVE_HIGH>;
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_ecspi1 &pinctrl_ecspi1_cs>;
spidev0: spidev@0 {
compatible = "toradex,evalspi";
reg = <0>;
spi-max-frequency = <23000000>;
GPIO status:
root@colibri-imx6ull:~# cat /sys/kernel/debug/gpio
gpiochip0: GPIOs 0-31, parent: platform/209c000.gpio, 209c000.gpio:
gpio-2 ( |VCC_USB[1-4] ) out lo
gpiochip1: GPIOs 32-63, parent: platform/20a0000.gpio, 20a0000.gpio:
gpiochip2: GPIOs 64-95, parent: platform/20a4000.gpio, 20a4000.gpio:
gpio-74 ( |spi_imx ) in lo
gpio-75 ( |spi_imx ) in lo
gpio-90 ( |spi_imx ) out hi
gpiochip3: GPIOs 96-127, parent: platform/20a8000.gpio, 20a8000.gpio:
gpiochip4: GPIOs 128-159, parent: platform/20ac000.gpio, 20ac000.gpio:
gpio-128 ( |cd ) in lo IRQ
gpio-129 ( |Wake-Up ) in lo IRQ
gpio-130 ( |id ) in lo IRQ
IOMUX status:
root@colibri-imx6ull:~# cat /sys/kernel/debug/pinctrl/pinctrl-maps | grep -A 6 spi
device 2008000.ecspi
state default
type MUX_GROUP (2)
controlling device 20e0000.iomuxc
group ecspi1grp
function imx6ull-colibri
state default
type CONFIGS_PIN (3)
pin MX6UL_PAD_LCD_DATA20
config 000000a0
state default
pin MX6UL_PAD_LCD_DATA22
config 000000a0
state default
pin MX6UL_PAD_LCD_DATA23
config 000100a0
state default
type MUX_GROUP (2)
group ecspi1_cs_grp
state default
pin MX6UL_PAD_LCD_DATA21
config 000000a0
state default
pin MX6UL_PAD_LCD_DATA05
config 000000a0
state default
pin MX6UL_PAD_LCD_DATA06
config 000000a0
spi devices:
root@colibri-imx6ull:~# ls /dev/ | grep spi
spidev0.0
What should I do to configure the other two chip-selects and get spidev0.1 & spidev0.2?
