isaac
January 22, 2018, 9:03am
1
The external RTC module m41t0 is enabled by default in imx7-colibri-eval-v3.dtsi:
/* M41T0M6 real time clock on carrier board */
rtc: m41t0m6@68 {
compatible = "st,m41t0";
reg = <0x68>;
How can I enable the internal RTC module instead (besides removing the above lines)?
I cannot find any examples of enabling RTC in other iMX7 dtb files and what should be added in DTB.
isaac
January 22, 2018, 1:20pm
2
I have found a solution but I am not sure if that’s correct.
By looking at the commit history of imx7d.dtsi , it seems the support for internal RTC of iMX7 was added around 2015 in this commit:
ARM: dts: imx7d: enable snvs rtc, onoffkey and power off ,
but later in 2016 somehow removed in the process of refactoring imx7d.dtsi into imx7s.dtsi and imx7d.dtsi in these two commits:
ARM: dts: imx7d: use imx7s.dtsi as base device tree
ARM: dts: imx7d: recreate imx7d.dtsi with i.MX 7Dual specifics
I copied the relevant node from the old imx7d.dtsi into imx7s.dtsi just to see how things would play.
I am not sure if this the correct way of enabling RTC. For instance, does it have any effect on caam-snvs which is already present in the DTS?
--- a/arch/arm/boot/dts/imx7s.dtsi
+++ b/arch/arm/boot/dts/imx7s.dtsi
@@ -643,6 +643,34 @@
reg = <0x30370000 0x10000>;
+ snvs: snvs@30370000 {
+ compatible = "fsl,sec-v4.0-mon", "syscon", "simple-mfd";
+ reg = <0x30370000 0x10000>;
+ snvs_rtc: snvs-rtc-lp {
+ compatible = "fsl,sec-v4.0-mon-rtc-lp";
+ regmap = <&snvs>;
+ offset = <0x34>;
+ interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>,
+ <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>;
+ snvs_poweroff: snvs-poweroff {
+ compatible = "syscon-poweroff";
+ regmap = <&snvs>;
+ offset = <0x38>;
+ mask = <0x60>;
+ snvs_pwrkey: snvs-powerkey {
+ compatible = "fsl,sec-v4.0-pwrkey";
+ regmap = <&snvs>;
+ interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>;
+ linux,keycode = <KEY_POWER>;
+ wakeup-source;
Now the rtc device shows up in the dmesg logs (I haven’t tested if rtc would actually preserve time as the battery is not wired on our board yet):
root@colibri-imx7-emmc:~# dmesg | grep -i rtc
[ 1.361285] snvs_rtc 30370000.snvs:snvs-rtc-lp: rtc core: registered 30370000.snvs:snvs- as rtc0
[ 1.900347] snvs_rtc 30370000.snvs:snvs-rtc-lp: setting system clock to 1970-01-01 00:00:00 UTC (0)
Is this the correct way of enabling internal RTC?
I suppose I can remove snvs_poweroff and snvs_pwrkey nodes. Is that correct?
Is there any consideration/side-effect for this configuration?
isaac
January 23, 2018, 1:21pm
4
Thanks for clarification.
We did some tests and I can confirm the internal RTC is now working as expected.
FWIW, I also pushed a fix onto our -next branch:
hi @isaac @stefan.tx
I’m using the toradex_4.9-1.0.x-imx-next branch.
i’m getting error on rtc . Not able to get logs like you , shown above.
[ 1.101602] rtc-ds1307: probe of 3-0068 failed with error -5
[ 1.107913] snvs_rtc 30370000.snvs:snvs-rtc-lp: rtc core: registered 30370000.snvs:snvs- as rtc1
[ 1.697822] hctosys: unable to open rtc device (rtc0)
Help me .
regards,
nikunj
hi @nikunjp26 : Could you ask a new question, please? Thanks.
