Finally we have a paritally working MAX14830 with the imx6q apalis/ixora boards.
We are using kernel 4.11.0 with this device tree (imx6q-apalis-ixora-zausan.dts)
#include "imx6q-apalis-ixora.dts"
&iomuxc
/* pins used on module */
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_reset_moci>;
16 HYS 0 CMOS input
1 Schmitt trigger input
15-14 PUS 00 100 kOhm Pull Down
01 47 kOhm Pull Up
10 100 kOhm Pull Up
11 22 kOhm Pull Up
13 PUE 0 Keeper enable
1 Pull enable Selection between keeper and pull up/down function
12 PKE 0 Pull/Keeper Disabled
1 Pull/Keeper Enabled Enable keeper or pull up/down function
11 ODE 0 Output is CMOS
1 Output is open drain
10-8 Reserved
7-6 SPEED 00 Reserved
01 Low (50 MHz)
10 Medium (100 MHz)
11 High (200 MHz)
5-3 DSE 000 output driver disabled (Hi Z)
001 240 Ohm
010 120 Ohm
011 80 Ohm
100 60 Ohm
101 48 Ohm
110 40 Ohm
111 34 Ohm If possible decrease the drive strength by increasing the resistance in order to reduce EMC problems
2-1 Reserved
0 SRE 0 Slow Slew Rate
1 Fast Slew Rate Use slow slew rate if possible for reducing EMC problems
// 0x100b1 1 00 0 0 0 000 10 110 00 1
// 0x130b0 1 00 1 1 0 000 10 110 00 0
// 0x170c1 1 01 1 1 0 000 11 000 00 1
// 0x000c1 0 00 0 0 0 000 11 000 00 1
// 0x100c1 1 00 0 0 0 000 11 000 00 1
pinctrl_ecspi1: ecspi1grp
fsl,pins = <
MX6QDL_PAD_CSI0_DAT6__ECSPI1_MISO 0x100b1
MX6QDL_PAD_CSI0_DAT5__ECSPI1_MOSI 0x100b1
MX6QDL_PAD_CSI0_DAT4__ECSPI1_SCLK 0x100b1
/* SPI1 cs */
MX6QDL_PAD_CSI0_DAT7__GPIO5_IO25 0x000b1
/* SPI1 cs2 (gpio2 del X27) */
MX6QDL_PAD_NANDF_D5__GPIO2_IO05 0x000b1
pinctrl_apalis_gpio1: gpio2io04grp
fsl,pins = <
/* Interrupcion para el MAX14830 (gpio1 del X27) */
MX6QDL_PAD_NANDF_D4__GPIO2_IO04 0x100c1
&iomuxc {
* Mux the Apalis GPIOs
* GPIO5, 6 used by optional fusion_F0710A kernel module
/* ZAUSAN - Quitamos la definicion de gpio1 porque la usamos nosotros para la interrupcion del MAX14830 */
/* ZAUSAN - Quitamos la definicion de gpio2 porque la usamos nosotros para el CS del MAX14830 */
pinctrl-0 = <
&pinctrl_apalis_gpio3 &pinctrl_apalis_gpio4
&pinctrl_apalis_gpio5 &pinctrl_apalis_gpio6
&pinctrl_apalis_gpio7 &pinctrl_apalis_gpio8
&ecspi1 {
/* Añadimos un CS adicional */
cs-gpios = <
&gpio5 25 GPIO_ACTIVE_HIGH
&gpio2 5 GPIO_ACTIVE_HIGH
pinctrl-0 = <&pinctrl_ecspi1>;
gpiom0: gpio@0 {
compatible = "microchip,mcp23s17";
#gpio-cells = <2>;
gpio-controller;
reg = <0>;
microchip,spi-present-mask = <0x3>;
spi-max-frequency = <10000000>;
#interrupt-cells = <2>;
max148300: max14830@0 {
compatible = "maxim,max14830";
reg = <1>; // GPIO2 de X27
clocks = <&xtal_max>;
clock-names = "xtal";
gpio-controller;
#gpio-cells = <2>;
spi-max-frequency = <16000000>;
//spi-max-frequency = <19000000>; // No funciona, detecta 0xd9
//spi-max-frequency = <20000000>; // No funciona, detecta 0xd9
/* Interrupcion */
interrupt-parent = <&gpio2>;
interrupts = <4 IRQ_TYPE_LEVEL_LOW>; // GPIO1 de X27, IRQ_TYPE_EDGE_FALLING IRQ_TYPE_LEVEL_LOW
pinctrl-0 = <&pinctrl_apalis_gpio1>;
xtal_max: xtal20@0
compatible = "fixed-clock";
#clock-cells = <0>;
clock-frequency = <3686400>;
With this configuration the gpio1 on X27 act as interrupt for the MAX14830 and gpio2 on X27 act as second CS for spi1. All works well, four serial ports detected (/dev/ttyMAX[0123]) and the asigned IRQ with number 119.
However we have a problem that we think is caused by the spi speed and/or irq management, the output of ‘cat /proc/cpuinfo’ shows this for IRQ 119:
119: 2 0 0 0 gpio-mxc 4 Edge spi0.1
As you can see, appears as “Edge” but on the device tree is of type “EDGE_LOW”.
When we run “minicom -D /dev/ttyMAX0” at 119200 8N1 (is a gps receiver sending data continuously, 50 mesages per second) on the console begins to appear:
[ 80.786948] max310x_handle_rx: 47 callbacks suppressed
[ 80.792128] max310x spi0.1: Possible RX FIFO overrun
[ 80.875589] max310x spi0.1: Possible RX FIFO overrun
[ 80.958868] max310x spi0.1: Possible RX FIFO overrun
[ 81.042031] max310x spi0.1: Possible RX FIFO overrun
[ 81.125203] max310x spi0.1: Possible RX FIFO overrun
and the received data from the serial port is incomplete (loss of some characters). The output of “top” is:
top - 10:47:05 up 0 min, 2 users, load average: 0,60, 0,14, 0,05
Tasks: 134 total, 2 running, 132 sleeping, 0 stopped, 0 zombie
%Cpu0 : 0,0 us, 94,8 sy, 0,0 ni, 0,0 id, 0,0 wa, 0,0 hi, 5,2 si, 0,0 st
%Cpu1 : 0,0 us, 3,8 sy, 0,0 ni, 96,2 id, 0,0 wa, 0,0 hi, 0,0 si, 0,0 st
%Cpu2 : 1,8 us, 8,8 sy, 0,0 ni, 89,5 id, 0,0 wa, 0,0 hi, 0,0 si, 0,0 st
%Cpu3 : 0,0 us, 0,0 sy, 0,0 ni,100,0 id, 0,0 wa, 0,0 hi, 0,0 si, 0,0 st
KiB Mem: 1018096 total, 115876 used, 902220 free, 8448 buffers
KiB Swap: 0 total, 0 used, 0 free. 51148 cached Mem
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
257 root -51 0 0 0 0 R 95,1 0,0 0:17.36 irq/119-spi0.1
101 root 20 0 0 0 0 S 8,6 0,0 0:01.94 spi0
478 root 20 0 4696 2128 1684 R 6,9 0,2 0:00.10 top
7 root 20 0 0 0 0 S 3,5 0,0 0:01.09 ksoftirqd/0
you can see a 95% of cpu load caused by the interrupt.
If we raise the spi-max-frequency above 16000000 the MAX14830 is not detected (MAX14830 spi bus can work at 26000000)
This is our actual setup:
What we don’t know is if the definition for the gpio1 is correct to manage an IRQ. What is the maximum speed of the spi bus?
thank you very much for your great support!
