I am trying to enable flexcan1 and flexcan2. I used the following patches.
for flexcan1:
diff --git a/arch/arm/boot/dts/imx7-colibri.dtsi b/arch/arm/boot/dts/imx7-colibri.dtsi
index 4a1ef3f83faf..159aec421789 100644
--- a/arch/arm/boot/dts/imx7-colibri.dtsi
+++ b/arch/arm/boot/dts/imx7-colibri.dtsi
@@ -134,7 +134,7 @@
&flexcan1 {
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_flexcan1>;
- status = "disabled";
+ status = "okay";
&flexcan2 {
@@ -458,8 +458,6 @@
pinctrl_gpio7: gpio7-grp { /* Alternatively CAN1 */
fsl,pins = <
- MX7D_PAD_ENET1_RGMII_RD3__GPIO7_IO3 0x14 /* SODIMM 55 */
- MX7D_PAD_ENET1_RGMII_RD2__GPIO7_IO2 0x14 /* SODIMM 63 */
@@ -523,8 +521,8 @@
pinctrl_flexcan1: flexcan1-grp {
fsl,pins = <
- MX7D_PAD_ENET1_RGMII_RD3__FLEXCAN1_TX 0x79 /* SODIMM 55 */
- MX7D_PAD_ENET1_RGMII_RD2__FLEXCAN1_RX 0x79 /* SODIMM 63 */
+ MX7D_PAD_ENET1_RGMII_RD3__FLEXCAN1_TX 0x59 /* SODIMM 55 */
+ MX7D_PAD_ENET1_RGMII_RD2__FLEXCAN1_RX 0x59 /* SODIMM 63 */
for flexcan2
index 159aec421789..4c6f5b6856c5 100644
@@ -413,12 +413,10 @@
MX7D_PAD_SD1_CD_B__GPIO5_IO0 0x74 /* SODIMM 69 */
MX7D_PAD_I2C4_SDA__GPIO4_IO15 0x14 /* SODIMM 75 */
MX7D_PAD_ECSPI1_MISO__GPIO4_IO18 0x14 /* SODIMM 79 */
- MX7D_PAD_I2C3_SCL__GPIO4_IO12 0x14 /* SODIMM 81 */
MX7D_PAD_ECSPI2_MISO__GPIO4_IO22 0x14 /* SODIMM 85 */
MX7D_PAD_ECSPI1_SS0__GPIO4_IO19 0x14 /* SODIMM 97 */
MX7D_PAD_ECSPI1_SCLK__GPIO4_IO16 0x14 /* SODIMM 101 */
MX7D_PAD_ECSPI1_MOSI__GPIO4_IO17 0x14 /* SODIMM 103 */
- MX7D_PAD_I2C3_SDA__GPIO4_IO13 0x14 /* SODIMM 94 */
MX7D_PAD_I2C4_SCL__GPIO4_IO14 0x14 /* SODIMM 96 */
MX7D_PAD_SD2_RESET_B__GPIO5_IO11 0x14 /* SODIMM 98 */
@@ -528,8 +526,8 @@
pinctrl_flexcan2: flexcan2-grp {
fsl,pins = <
- MX7D_PAD_GPIO1_IO14__FLEXCAN2_RX 0x79 /* SODIMM 188 */
- MX7D_PAD_GPIO1_IO15__FLEXCAN2_TX 0x79 /* SODIMM 178 */
+ MX7D_PAD_I2C3_SCL__FLEXCAN2_RX 0x59 /* SODIMM 81 */
+ MX7D_PAD_I2C3_SDA__FLEXCAN2_TX 0x59 /* SODIMM 94 */
diff --git a/arch/arm/boot/dts/imx7d-colibri-emmc-eval-v3.dts b/arch/arm/boot/dts/imx7d-colibri-emmc-eval-v3.dts
index a2164e979606..d6d02525a1b1 100644
--- a/arch/arm/boot/dts/imx7d-colibri-emmc-eval-v3.dts
+++ b/arch/arm/boot/dts/imx7d-colibri-emmc-eval-v3.dts
@@ -21,3 +21,9 @@
vbus-supply = <®_usbh_vbus>;
+&flexcan2 {
+ pinctrl-names = "default";
+ pinctrl-0 = <&pinctrl_flexcan2>;
+ status = "okay";
After boot and enabling both interfaces in dmesg is this output
[ 6.255424] flexcan 30a00000.can: device registered (reg_base=f5a00000, irq=59)
[ 6.325845] flexcan 30a10000.can: device registered (reg_base=f5a10000, irq=60)
I used cansend and candump to send and receive a message but nothing happened.
I use linux- toradex branch toradex_4.9-2.3.x-imx.
any advice which can help me?
