How to edit the size of the splash screen that will match the Capacitive Touch Display 10.1" LVDS
Hi Toradex Community,
How to edit the size of the splash screen that will match the Capacitive Touch Display 10.1" LVDS.
I ’ am using the TorizonCore Builder to customize the Torizon OS by adding a splash screen :
  • 1920X155 Pixel
  • Format png
The Capacitive Touch Display 10.1" LVDS:
  • Resolution: 1280x800px
  • LVDS 8-bit
More general how I could set up the TorizonCore Builder that will displays the splach screen depending on the size of the Display(HDMI, LDVS…)
Any Help?
Ahmed49
Hello @Ahmed49,
To do that, you can simply resize your image to the intended resolution, adding padding if distorting the image is not intended.
With the image in the correct resolution, you can set it with TorizonCore builder: Splash Screen on Torizon OS | Toradex Developer Center
Regarding the multiple resolutions question, I will answer you in your other topic.
Bruno
Hello @Ahmed49,
Were you able to get this issue resolved?
Or do you need further support with this topic?
Bruno
