I’m trying to disable ipv6 (we have no use of it and we’re currently debugging network issues so we’d like to take ipv6 out of the possible source for issue).
I did the systcl.conf technique by adding this to the /etc/sysctl.conf :
But i’d like to disable the ipv6 stack completely, at the kernel level, i tried to find a way to update kernel cmdline parameters, ideally from user space, is there any way to achieve this ?
We’re using toradex SOM on colibri carrier board :
Hi @jeremias.tx ,
Thanks for your answer, from my understanding the solution based on torizonCore Builder is only in a “custom” kernel building, am I wrong ?
Regarding the U-Boot solution, which seems to answer my request of updating the kernel cmdline without the need of building a custom kernel, do you have any guide to ease the implementation of this solution ?
TorizonCore Builder does not in any case re-build the linux kernel itself. It only makes small modifications. In this case all it would be doing is appending kernel arguments to the existing kernel command line. This does not require building a custom kernel.
It’s fairly self explanatory, you just need to set a value of tdxargs in U-Boot. Whatever is in tdxargs gets appended to the kernel command line. If tdxargs is equal to foo then foo will be appended onto the kernel command line. If you don’t know how to modify environment variables in U-Boot then look here: U-Boot | Toradex Developer Center
