Hello, I have problem with cross-compiling my FLTK gui for Toradex Version 2.8 LTS. Until now I use colibri iMX6S and version 2.7, but now we want to migrate to version 2.8.
In previous version everything works with fltk-config script. We use it in custom make file. But for test I using now command: fltk-config --compile helloWord.cxx
In version 2.8 and I check also version 5.0 this procedure doesn’t work. If I look into script I can find wrong paths:
prefix=/home/klemen/colibri28/oe-core/build/tmp-glibc/work/armv7at2hf-neon-mx6qdl-angstrom-linux-gnueabi/fltk/1.3.5-r0/build
but this directory doesn’t exist and also I get compile error libfltk.a:No such file or directory. I change this into: prefix=/home/klemen/colibri28/oe-core/build/tmp-glibc/sysroots-components/armv7at2hf-neon-mx6qdl/fltk/usr
than I get error fatal error: FL/Fl.H: No such file or directory
I change also includedir=/home/klemen/colibri28/oe-core/build/tmp-glibc/work/armv7at2hf-neon-mx6qdl-angstrom-linux-gnueabi/fltk/1.3.5-r0/fltk-1.3.5
to includedir=/home/klemen/colibri28/oe-core/build/tmp-glibc/sysroots-components/armv7at2hf-neon-mx6qdl/fltk/usr/include
than I get error fatal error: stdio.h: No such file or directory
So probably I will never come to the end with this errors. Could someone give me working fltk-config for Toradex-Yocto Version 2.8 LTS. Or some tip how to deal with this issue.
Is it ok if I use instead of CXX="FIXMESTAGINGDIRTARGET-native/usr/bin/arm-angstrom-linux-gnueabi/arm-angstrom-linux-gnueabi-g++"
just like in previuos versions (is that the same?) CXX="arm-linux-gnueabihf-gcc"
in fltk-crosscompile script is also --sysroot=FIXMESTAGINGDIRTARGET
to which directory should point --sysroot in version 2.7 was ~/oe-core/build/tmp-glibc/sysroots/colibri-imx6/
is this new --sysroot=~/oe-core/build/tmp-glibc/sysroots-components/armv7ahf-neon/glibc/ ?
If I add into include also this path /oe-core/build/tmp-glibc/sysroots-components/armv7ahf-neon/glibc/ I get linker error:
Toradex does not have experience with FLTK. Looking into our community and found the following thread:
You might be better off either contacting the user that used it on their end or contacting FLTK support, I am pretty sure this is a better fit than the Toradex support.
