I’m working on customizing a Yocto-based Linux image for the Toradex Verdin iMX8M Plus board.
What I want to achieve:
Include a prebuilt executable (PIC) in the image
Ensure the binary runs automatically at boot
Automatically create a custom directory, for example: /root/store
My questions:
What is the proper way in Yocto to include custom files like a compiled binary into the image?
How can I create a specific directory (e.g., /root/store) during image build so that it’s present in the final root filesystem?
What is the best practice to set up a systemd service so that the executable starts on boot?
Where should I install the binary and service file in the recipe?
Are there recommended examples or references that show how to package and auto-start an application in Yocto for Toradex or similar boards?
Additional info:
Board: Verdin iMX8M Plus
Yocto Version: Toradex BSP 6.x
The executable is Qt5-based and was cross-compiled using the appropriate toolchain.
I’m currently writing a .bb recipe and a .service file, but I’d prefer to follow the correct and standard method to avoid packaging errors or missing runtime dependencies.
Any help, guidance, or references would be much appreciated!
Thank you.
Hello! Thank you for your detailed questions. Here are step-by-step answers and best practices for packaging and auto-starting your Qt5 application on your Verdin iMX8M Plus using Yocto with Toradex BSP 6.x.
1. Including a Prebuilt Executable in the Image
Create a Custom Layer and Recipe
Start by creating a custom meta-layer if you have not already. Add your binary (your-qt5-app) to the files directory inside your recipe.
Example recipe (your-qt5-app_1.0.bb):
SUMMARY = "Your Qt5 Application"
LICENSE = "MIT"
LIC_FILES_CHKSUM = "file://${COREBASE}/meta/files/common-licenses/MIT;md5=0835ade698e0bcf8506ecda2f7b4f302"
SRC_URI = "file://your-qt5-app \
file://your-qt5-app.service"
S = "${WORKDIR}"
# Install binary to /usr/bin and create /root/store directory
do_install() {
install -d ${D}${bindir}
install -m 0755 ${S}/your-qt5-app ${D}${bindir}
install -d ${D}/root/store
# Install systemd service
install -d ${D}${systemd_unitdir}/system
install -m 0644 ${WORKDIR}/your-qt5-app.service ${D}${systemd_unitdir}/system
inherit systemd
NATIVE_SYSTEMD_SUPPORT = "1"
SYSTEMD_PACKAGES = "${PN}"
SYSTEMD_SERVICE_${PN} = "your-qt5-app.service"
# Qt5 dependencies (adjust modules as needed)
DEPENDS = "qtdeclarative qtgraphicaleffects"
RDEPENDS_${PN} = "qtdeclarative-qmlplugins qtgraphicaleffects-qmlplugins"
References:
Add custom binaries with Yocto
2. Creating a Custom Directory (e.g., /root/store)
3. Systemd Service for Auto-Start at Boot
Create your-qt5-app.service alongside your binary in the recipe’s files directory, for example:
[Unit]
Description=Your Qt5 application service
After=multi-user.target
[Service]
Type=simple
ExecStart=/usr/bin/your-qt5-app
[Install]
WantedBy=multi-user.target
Let your recipe inherit systemd and install the service as described above.
References:
How to autorun application at the start-up in Linux
4. Where to Install the Binary and Service File
- Binaries:
/usr/bin (use ${bindir} in recipe)
- Service files:
${systemd_unitdir}/system (typically /lib/systemd/system or /usr/lib/systemd/system depending on your distro)
Your do_install() in the recipe (see point 1) assures this layout.
5. References & Examples
Best Practices for Qt5 Applications
- Ensure Qt5 libraries (and any needed plugins) are present at runtime. Add the required Qt5 modules to
DEPENDS and RDEPENDS_${PN} as shown.
- Always test the resulting image in QEMU or on hardware to verify that your binary runs and the directory exists.
- Add your new package to the image with
IMAGE_INSTALL:append = " your-qt5-app" in conf/local.conf or in a custom image recipe.
If you follow these steps, your prebuilt Qt5 executable will be properly packaged, the /root/store directory will be present, and the application will auto-start at boot using systemd.
Let me know if you’d like a more detailed example for any of the files!
What I Did
My goal is to add a custom executable (pic) that auto-starts on boot. I created the following recipe and file structure in my custom meta-layer:
1. Directory Structure:
meta-my-layer/
└── recipes-kernel/
└── pic/
├── files/
│ ├── pic (My pre-compiled executable)
│ └── pic.service (My systemd service file)
└── pic_1.0.bb (My recipe file)`
2. Recipe Content (pic_1.0.bb):
BashSUMMARY = "PIC Qt Executable and Service"
LICENSE = "CLOSED"
LIC_FILES_CHKSUM = ""
SRC_URI = "file://pic file://pic.service"
S = "${WORKDIR}"
inherit systemd
SYSTEMD_SERVICE:${PN} = "pic.service"
FILES:${PN} += "${bindir}/pic"
do_install() {
install -m 0755 ${WORKDIR}/pic ${D}${bindir}/
install -m 0644 ${WORKDIR}/pic.service ${D}${systemd_system_unitdir}/
The Problem
Before adding this recipe, the build seemed to work fine. After adding it and running bitbake, the build fails while trying to fetch an official Toradex recipe (backports), which is completely unrelated to my changes.
Error Log Snippet:
ERROR: ExpansionError during parsing ... backports_5.4.bb
fatal: unable to access 'https://git.toradex.com/backports-toradex.git/': Failed to connect to git.toradex.com port 443: Connection refused`
My Question
How can my recipe, which only uses local file:// sources, cause a network error in a different recipe? Is it possible that my change is triggering this, or is this just a coincidental network/firewall issue on my side?
Thank you for your help.
