Hi @sjjin , I tested with RDP and found the same behaviors. It seems chromium has a bug to interpret additional input when using Wayland. There was a patch from this ticket. The same issue was also discussed on Chromium Community. However, I am not sure if this is still working on BSP 7.2.0. Is remote access(VNC/RDP) mandatory in your project? Or is it a way to make development easier?
