Is there a document that clearly describes files required on a SD card to make an image compatible with TEZI?
I am trying to create the SD card suitable for loading the bootloader, kernel and filesystem into the eMMC using TEZI
For pre-built image you just need to unpack it to SD card. See details here.
If you building an OS image using OpenEmbedded/Yocto TEZI compatible image will be generated automatically.
If you want to modify image manually please read this.
