I am using a Colibri iMX7 module with TorizonCore and trying to set up a 7-inch resistive touch display.
I have applied the colibri-imx7_panel-res-touch-7inch_overlay.dtbo overlay by adding it to overlays.txt and also using setenv overlays colibri-imx7_panel-res-touch-7inch_overlay.dtbo in U-Boot followed by saveenv.
After reboot, the display shows output but the image is not correct — the resolution or timings seem off. cat /sys/class/graphics/fb0/modes shows U:800x480p-0.
Could you guide me on what else I need to configure, or if I should create a custom overlay with specific timing values? Any help on debugging or best practices would be appreciated.
Hello! Thank you for your detailed description of your setup and the steps you’ve taken so far.
Based on your description, you are seeing a reported resolution of 800x480 in /sys/class/graphics/fb0/modes, but the official Toradex overlays for the Resistive Touch Display 7" Parallel are configured for a default resolution of 640x480 on the Colibri iMX7 when using the standard overlay colibri-imx7_panel-res-touch-7inch_overlay.dtbo. If you are getting a different resolution, here are some steps and checks to clarify and help you debug:
1. Overlay Selection and OS Version
- Ensure you are using TorizonCore version 6.0.0 or newer, as this overlay is only supported from that version onwards (source).
- Only specify one method to set overlays: either via the
overlays.txtfile or with U-Bootsetenv+saveenv. Using both may cause unpredicted behavior.- Using
overlays.txtin the boot partition is recommended for TorizonCore.
- Using
2. Hardware Connection Check
- Make sure the display is properly connected to the carrier board and that pin 1 of the display matches pin 1 on the board connector. FFC connectors are delicate—handle the brown levers gently (installation guide).
- Improper connection can cause incorrect detection or garbled images.
3. Test for EDID/Detection
- The 7-inch resistive touch display is parallel and does not use EDID, but you can still verify what the kernel thinks is attached:
This is mostly for HDMI/LVDS displays, but running it can help spot if some unexpected detection is happening (reference).find /sys/devices -name "edid"
4. Test with Weston/Software Stack
- Use the Weston Wayland compositor to test if the display and touch functionality are working correctly:
This step checks that the software layers are working as expected (testing instructions).docker-compose -f /etc/docker/compose/docker-compose.weston.yml up -d
5. Custom Overlay Only If Needed
- If the image is not displayed correctly and you’ve confirmed the display is properly connected and the supported overlay (
colibri-imx7_panel-res-touch-7inch_overlay.dtbo) is used, you normally should not need a custom overlay for standard Toradex 7" resistive touch displays—unless you’re using a different display model with different timings. - If you’re not using the Toradex 7" resistive touch display, or if you have a unique display module, then creating a custom overlay with the specific timing values would be required.
6. Next Steps
- Double-check your overlay method and ensure only one is in use.
- Re-seat the display connector and verify the ribbons are secure.
- Confirm your OS and overlays are up to date.
- If the above does not resolve the issue and you are using a non-Toradex display, please provide your display’s datasheet so timing values for a custom overlay can be determined.
For further reading on setup and troubleshooting, see:
- Setting up displays with Torizon
- First steps with Resistive Touch Display 7"
- Device tree overlays for peripherals
Let me know if you’re using the standard Toradex 7" display or a different model, or if the above steps resolve your issue!
I am getting this type of window.
torizon@colibri-imx7-emmc-06673350:/$ ls /boot/ostree/torizon-*/dtb/overlays
colibri-imx7_panel-cap-touch-10inch-lvds_overlay.dtbo colibri-imx7_panel-res-touch-7inch_overlay.dtbo
colibri-imx7_panel-cap-touch-7inch_adapter_overlay.dtbo colibri-imx7_spidev_overlay.dtbo
colibri-imx7_panel-cap-touch-7inch_overlay.dtbo colibri-imx7_vga-640x480_overlay.dtbo
i set overlay.txt = colibri-imx7_panel-res-touch-7inch_overlay.dtbo and after that i reboot so what i do next.
Greetings @intersense.design,
Just to confirm, this is the 7-inch resistive display sold by Toradex, correct?
Just checking since our overlays are specific to the displays we sell.
yes
Okay thank you for confirming. I forgot to ask prior, but what version of Torizon are you running here? Also is this out-of-the-box Torizon or did you make any modifications to the OS?
We just want to make sure we’re comparing using the same versions you are using.
