Technical Support queries
I want to control X1 pin 87 which is already reserved for ResetOut#. please tell me easiest possible way how i can do that.
The Hight state of ResetOut# signal indicate that module is fully powered and running . That pin controlled by PIMIC and here is no ease way to control it by software.
Could you please explain what is a reason you want to control it?
@alex.tx Thanks for your reply!
We made a design with two IMX7d colibri modules and for testing purpose in want to make RestOut# low.
Can I do it anyhow using device tree or something else? is there any way to do so?
There is no way to control the pin 87 . However you can place a gate on your carrier board between Pin 87 and board’s RestOut#, and control that gate by any other GPIO
