How to choose the program in TS file with gstreamer?
I’m working on Apalis IMX6 using Yocto.
I would like to play a TS file using Gstreamer and choose the played program.
At this time, i use the following command :
gst-launch-1.0 filesrc location=/mnt/usb/HD5_6Mbps_5min_v2.trp ! decodebin name = dec dec. ! queue ! audioconvert ! volume volume=10 ! alsasink dec. ! queue ! videoconvert ! imxg2dvideosink
This works fine but it’s always the first program of the TS file which is played.
Thanks in advance for your help.
  • Use a concrete pipe-line rather than using decodebin trying to detect demuxer.
  • NXP’s i.MX Linux User’s Guide may have some more usage information for multimedia use cases.
  • Their community may also have more specific answers in the multimedia domain.
  • You demuxer of choice may have a property to specify resp. program e.g. have a look at the output of the following command:
    gst-inspect-1.0 aiurdemux
Advantage of using decodebin is that video+audio codec is chosen automatically.
In the same TS, i can have MPEG2 video + MPEG4 Video.
It’s very hard to detect the stream, and build the pipe with good video codec + good audio codec !
Sure, I’m fully aware of decodebin’s advantages however if you want something rather special like being able to choose a particular program from an MPEG transport stream then I guess decodebin might not be able to serve you.
You can't have your cake and eat it too!
You might want to consider playbin rather than decodebin.
It has a property called current-audio and current-video that can be used to select a stream other than the default one.
of course but on my hardware, decodebin works better than playbin.
