Hi bhuvan
Thanks for your answer.
Here is all what I have done :
bitbake -c clean /virtual/kernel
bitbake -c menuconfig virtual/kernel
— Bootup logo │ │
│ │ Standard black and white Linux logo │ │
│ │ Standard 16-color Linux logo │ │
│ │ Standard 224-color Linux logo │ │
│ │ [*] Custom 224-color Linux logo
I’ve put my ascii logo renamed to logo_custom_clut224.ppm in :
~/oe-core/build/tmp-glibc/work-shared/apalis-t30/kernel-source/drivers/video/logo
then :
bitbake -f -c compile virtual/linux
bitbake virtual/linux
I can see the logo_custom_clut224.c in build/tmp-glibc/work/apalis_t30-angstrom-linux-gnueabi/linux-toradex/3.1.10+gitra24d47d56d9f5a6ed1ec3a42c6d9ccf5748bc2ba-2.7.3/build/drivers/video/logo
After that :
cp …/deploy/images/apalis-t30/uImage /media/nazim/406D-B804/apalis_t30/
and finally on u-boot :
run setupdate
run update_kernel
reset
Here is the kernel boot:
Starting kernel ...
[ 0.000000] Linux version 3.1.10-2.7.3+ga24d47d (nazim@ubuntu) (gcc version 6.2.1 20161016 (Linaro GCC 6.2-2016.11) ) #1 SMP PREEMPT Thu Jul 20 10:54:58 CEST 2017
[ 0.000000] CPU: ARMv7 Processor [412fc099] revision 9 (ARMv7), cr=10c5387d
[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine: Toradex Apalis T30
[ 0.000000] Found fbmem: 00c00000@ff300000
[ 0.000000] Tegra reserved memory:
[ 0.000000] LP0: 00000000 - 00000000
[ 0.000000] Bootloader framebuffer: ff300000 - ffefffff
[ 0.000000] Bootloader framebuffer2: 00000000 - 00000000
[ 0.000000] Framebuffer: fe600000 - feefffff
[ 0.000000] 2nd Framebuffer: fef00000 - ffefffff
[ 0.000000] Carveout: 00000000 - 00000000
[ 0.000000] Vpr: 00000000 - 00000000
[ 0.000000] Memory policy: ECC disabled, Data cache writealloc
[ 0.000000] fuse_speedo_calib: ATE prog ver 4.0
[ 0.000000] Tegra3: CPU Speedo ID 2, Soc Speedo ID 2
[ 0.000000] Tegra Revision: A03 SKU: 0xb1 CPU Process: 2 Core Process: 0
[ 0.000000] tegra: PLLP fixed rate: 408000000
[ 0.000000] Lowering sbus maximum rate from 378000000 to 334000000
[ 0.000000] Lowering vde maximum rate from 600000000 to 520000000
[ 0.000000] Lowering mpe maximum rate from 600000000 to 520000000
[ 0.000000] Lowering 2d maximum rate from 600000000 to 520000000
[ 0.000000] Lowering epp maximum rate from 600000000 to 520000000
[ 0.000000] Lowering 3d maximum rate from 600000000 to 520000000
[ 0.000000] Lowering 3d2 maximum rate from 600000000 to 520000000
[ 0.000000] Lowering se maximum rate from 625000000 to 520000000
[ 0.000000] Lowering host1x maximum rate from 300000000 to 267000000
[ 0.000000] Lowering cbus maximum rate from 700000000 to 520000000
[ 0.000000] Lowering pll_c maximum rate from 1400000000 to 1066000000
[ 0.000000] Lowering ndflash maximum rate from 240000000 to 200000000
[ 0.000000] Lowering sbc1 maximum rate from 160000000 to 100000000
[ 0.000000] Lowering sbc2 maximum rate from 160000000 to 100000000
[ 0.000000] Lowering sbc3 maximum rate from 160000000 to 100000000
[ 0.000000] Lowering sbc4 maximum rate from 160000000 to 100000000
[ 0.000000] Lowering sbc5 maximum rate from 160000000 to 100000000
[ 0.000000] Lowering sbc6 maximum rate from 160000000 to 100000000
[ 0.000000] Lowering dsia maximum rate from 500000000 to 432500000
[ 0.000000] Lowering dsib maximum rate from 500000000 to 432500000
[ 0.000000] Lowering cpu_g maximum rate from 1700000000 to 1400000000
[ 0.000000] tegra3_dvfs: cold offset 50000000 is too high for regular dvfs limit 1000000
[ 0.000000] tegra dvfs: VDD_CPU nominal 1125mV, scaling enabled
[ 0.000000] tegra dvfs: VDD_CORE nominal 1300mV, scaling enabled
[ 0.000000] L310 cache controller enabled
[ 0.000000] l2x0: 8 ways, CACHE_ID 0x410000c7, AUX_CTRL 0x7e080001, Cache size: 1048576 B
[ 0.000000] PERCPU: Embedded 8 pages/cpu @c1dfd000 s10336 r8192 d14240 u32768
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 512797
[ 0.000000] Kernel command line: core_edp_mv=1300 usb_high_speed=1 ip=off root=/dev/mmcblk0p2 rw,noatime rootfstype=ext3 rootwait igb_mac= consoleblank=0 no_console_suspend=1 console=tty1 console=ttyS0,115200n8 debug_uartport=lsport,0 vmalloc=256M mem=2035M@2048M fbmem=12M@4083M video=tegrafb0:640x480-16@60 fbcon=map:1
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 2021MB = 2021MB total
[ 0.000000] Memory: 2037860k/2037860k available, 45980k reserved, 1414144K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] DMA : 0xff000000 - 0xffe00000 ( 14 MB)
[ 0.000000] vmalloc : 0xe8800000 - 0xf8000000 ( 248 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe8000000 ( 640 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc085e4d0 (8538 kB)
[ 0.000000] .init : 0xc085f000 - 0xc090f860 ( 707 kB)
[ 0.000000] .data : 0xc0910000 - 0xc099dfe4 ( 568 kB)
[ 0.000000] .bss : 0xc099e008 - 0xc0a16de8 ( 484 kB)
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:800
[ 0.000000] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 4294967ms
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [tty1] enabled
[ 0.003100] Calibrating delay loop... 1196.85 BogoMIPS (lpj=5984256)
[ 0.090128] pid_max: default: 32768 minimum: 301
[ 0.090497] Mount-cache hash table entries: 512
[ 0.091752] Initializing cgroup subsys blkio
[ 0.091893] CPU: Testing write buffer coherency: ok
[ 0.091992] ftrace: allocating 23986 entries in 71 pages
[ 0.124684] Brought up 4 CPUs
[ 0.124730] SMP: Total of 4 processors activated (4787.40 BogoMIPS).
[ 0.125891] devtmpfs: initialized
[ 0.131380] print_constraints: dummy:
[ 0.131788] NET: Registered protocol family 16
[ 0.133093] host1x bus init
[ 0.133325] Serial: 8250/16550 driver, 9 ports, IRQ sharing disabled
[ 0.407149] apalis_t30_edp_init: CPU regulator 6000 mA
[ 0.407242] Selecting UARTA as the debug console
[ 0.407285] The debug console clock name is uarta_dbg
[ 0.407652] serial8250.0: ttyS0 at MMIO 0x70006000 (irq = 68) is a Tegra
[ 0.943114] console [ttyS0] enabled
[ 0.973642] Registering the device TPS62360
[ 0.978417] Clear bootloader IO dpd settings
[ 1.063793] tegra: invalid EMC DFS table: entry for max rate 800000 kHz is not found
[ 1.074448] tegra_iovmm_register: added iovmm-smmu
[ 1.091264] bio: create slab <bio-0> at 0
[ 1.096099] i2c-core: driver [tps6591x] using legacy suspend method
[ 1.102412] i2c-core: driver [tps6591x] using legacy resume method
[ 1.109091] SCSI subsystem initialized
[ 1.115834] usbcore: registered new interface driver usbfs
[ 1.121486] usbcore: registered new interface driver hub
[ 1.126943] usbcore: registered new device driver usb
[ 1.132162] tegra-otg tegra-otg: otg transceiver registered
[ 1.139571] stmpe 4-0041: stmpe811 detected, chip id: 0x811
[ 1.146485] tps6591x 4-002d: VERNUM is 02
[ 1.152898] print_constraints: tps6591x_VDD_1: 1350 mV normal standby
[ 1.161202] print_constraints: tps6591x_VDD_2: 1050 mV normal standby
[ 1.169176] print_constraints: tps6591x_VDDCTRL: 800 <--> 1300 mV at 1012 mV normal standby
[ 1.178247] print_constraints: tps6591x_VIO: 1800 mV normal standby
[ 1.185847] print_constraints: tps6591x_LDO_1: 1800 mV normal standby
[ 1.192351] set_supply: tps6591x_LDO_1: supplied by tps6591x_VIO
[ 1.199565] print_constraints: tps6591x_LDO_2: 1200 mV normal standby
[ 1.206070] set_supply: tps6591x_LDO_2: supplied by tps6591x_VIO
[ 1.212670] print_constraints: tps6591x_LDO_3: 1200 mV normal standby
[ 1.219830] print_constraints: tps6591x_LDO_4: 1000 <--> 1400 mV at 1200 mV normal standby
[ 1.228662] print_constraints: tps6591x_LDO_5: 2800 mV normal standby
[ 1.235691] print_constraints: tps6591x_LDO_6: 1000 <--> 1100 mV at 1000 mV normal standby
[ 1.244025] set_supply: tps6591x_LDO_6: supplied by tps6591x_VIO
[ 1.251346] print_constraints: tps6591x_LDO_7: 1200 mV normal standby
[ 1.257834] set_supply: tps6591x_LDO_7: supplied by tps6591x_VIO
[ 1.264916] print_constraints: tps6591x_LDO_8: 1000 mV normal standby
[ 1.271422] set_supply: tps6591x_LDO_8: supplied by tps6591x_VIO
[ 1.280246] print_constraints: tps62360: 900 <--> 1400 mV at 1200 mV normal standby
[ 1.288228] pps_core: LinuxPPS API ver. 1 registered
[ 1.293233] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.302441] PTP clock support registered
[ 1.306726] Advanced Linux Sound Architecture Driver Version 1.0.24.
[ 1.313759] Bluetooth: Core ver 2.16
[ 1.317410] NET: Registered protocol family 31
[ 1.321892] Bluetooth: HCI device and connection manager initialized
[ 1.328270] Bluetooth: HCI socket layer initialized
[ 1.333177] Bluetooth: L2CAP socket layer initialized
[ 1.338291] Bluetooth: SCO socket layer initialized
[ 1.343641] cfg80211: Calling CRDA to update world regulatory domain
[ 1.351530] print_constraints: fixed_reg_en_hdmi: 1800 mV normal
[ 1.357969] print_constraints: fixed_reg_v3_3: 3300 mV normal
[ 1.364301] print_constraints: gpio_reg_sdmmc3_vdd_sel: 1800 <--> 3300 mV at 1800 mV normal standby
[ 1.373421] set_supply: gpio_reg_sdmmc3_vdd_sel: supplied by fixed_reg_v3_3
[ 1.381273] tegra: failed to map regulator to power detect cell pwrdet_sdmmc3(-19)
[ 1.388992] tegra: failed regulators mapping - io power detection is left always on
[ 1.396694] Switching to clocksource timer_us
[ 1.414018] nvmap_page_pool_init: nvmap uc page pool size=63683 pages
[ 1.487577] nvmap_page_pool_init: nvmap pool = uc, highmem=63683, pool_size=63683,totalram=509465, freeram=444886, totalhigh=353536, freehigh=289707
[ 1.787582] nvmap_page_pool_init: nvmap wc page pool size=63683 pages
[ 1.861321] nvmap_page_pool_init: nvmap pool = wc, highmem=63683, pool_size=63683,totalram=509465, freeram=381088, totalhigh=353536, freehigh=225909
[ 2.160621] nvmap_page_pool_init: nvmap iwb page pool size=63683 pages
[ 2.234404] nvmap_page_pool_init: nvmap pool = iwb, highmem=63683, pool_size=63683,totalram=509465, freeram=317259, totalhigh=353536, freehigh=162080
[ 2.534964] tegra-nvmap tegra-nvmap: created carveout iram (255KiB)
[ 2.555948] NET: Registered protocol family 2
[ 2.560580] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 2.568389] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 2.578353] TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
[ 2.586816] TCP: Hash tables configured (established 131072 bind 65536)
[ 2.593468] TCP reno registered
[ 2.596633] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 2.602627] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 2.609411] NET: Registered protocol family 1
[ 2.614262] RPC: Registered named UNIX socket transport module.
[ 2.620207] RPC: Registered udp transport module.
[ 2.624954] RPC: Registered tcp transport module.
[ 2.629675] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 2.638969] host1x host1x: initialized
[ 2.642887] PMU: registered new PMU device of type 0
[ 2.648384] Tegra auto-hotplug initialized: disabled
[ 2.653407] cpu-tegra: init EDP limit: 1250 MHz
[ 2.658710] PCIE.C: tegra_pcie_enable_regulators : regulator hvdd_pex
[ 2.665286] PCIE.C: tegra_pcie_enable_regulators : regulator pexio
[ 2.671529] tegra_pcie_enable_regulators: unable to get pexio regulator
[ 2.678165] PCIE.C: tegra_pcie_enable_regulators : regulator avdd_plle
[ 2.887199] PCIE: port 0: link down, retrying
[ 3.091883] PCIE: port 0: link down, retrying
[ 3.296555] PCIE: port 0: link down, retrying
[ 3.300912] PCIE: port 0: link down, ignoring
[ 3.505593] PCIE: port 1: link down, retrying
[ 3.710263] PCIE: port 1: link down, retrying
[ 3.914951] PCIE: port 1: link down, retrying
[ 3.919307] PCIE: port 1: link down, ignoring
[ 3.923899] PCI: bus0: Fast back to back transfers disabled
[ 3.941146] PCI: bus1: Fast back to back transfers disabled
[ 3.946983] pci 0000:00:00.0: BAR 8: assigned [mem 0x10000000-0x100fffff]
[ 3.953792] pci 0000:00:00.0: BAR 7: assigned [io 0x10000000-0x10000fff]
[ 3.960585] pci 0000:01:00.0: BAR 0: assigned [mem 0x10000000-0x1001ffff]
[ 3.967391] pci 0000:01:00.0: BAR 0: set to [mem 0x10000000-0x1001ffff] (PCI address [0x10000000-0x1001ffff])
[ 3.977318] pci 0000:01:00.0: BAR 3: assigned [mem 0x10020000-0x10023fff]
[ 3.984121] pci 0000:01:00.0: BAR 3: set to [mem 0x10020000-0x10023fff] (PCI address [0x10020000-0x10023fff])
[ 3.994046] pci 0000:01:00.0: BAR 2: assigned [io 0x10000000-0x1000001f]
[ 4.000841] pci 0000:01:00.0: BAR 2: set to [io 0x10000000-0x1000001f] (PCI address [0x10000000-0x1000001f])
[ 4.010828] pci 0000:00:00.0: PCI bridge to [bus 01-01]
[ 4.016073] pci 0000:00:00.0: bridge window [io 0x10000000-0x10000fff]
[ 4.022873] pci 0000:00:00.0: bridge window [mem 0x10000000-0x100fffff]
[ 4.060697] highmem bounce pool size: 64 pages
[ 4.065763] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 4.072823] fuse init (API version 7.17)
[ 4.077014] msgmni has been set to 1218
[ 4.081717] io scheduler noop registered (default)
[ 4.088355] mpe mpe: initialized
[ 4.093876] gr3d gr3d: initialized
[ 4.099463] gr2d gr2d: initialized
[ 4.103371] isp isp: initialized
[ 4.107166] tegradc tegradc.0: probed
[ 4.110933] tegradc tegradc.0: use cmd options for tegrafb0: 640x480-16@60
[ 4.117841] tegradc tegradc.0: switching framebuffer to 640x480
[ 4.123773] tegradc tegradc.0: Calculated sync href=0 vref=1
[ 4.129435] tegradc tegradc.0: using mode 640x480 pclk=25175000 href=0 vref=1
[ 4.141062] tegradc tegradc.0: probed
[ 4.158023] tegradc tegradc.1: probed
[ 4.161931] tegradc tegradc.1: use default mode for tegrafb1: 640x480-16@60
[ 4.168903] tegradc tegradc.1: Unusuall display aspect ratio. You may encounter problems with base resolution
[ 4.180222] tegradc tegradc.1: Unusuall display aspect ratio. You may encounter problems with base resolution
[ 4.191539] tegradc tegradc.1: Unusuall display aspect ratio. You may encounter problems with base resolution
[ 4.202859] tegradc tegradc.1: switching framebuffer to 640x480
[ 4.208781] tegradc tegradc.1: using mode 640x480 pclk=23750000 href=1 vref=1
[ 4.220996] tegradc tegradc.1: hdmi: can't set audio to 44100 at 23750000 pix_clock
[ 4.228787] tegradc tegradc.1: switching framebuffer to 640x480
[ 4.228797] tegradc tegradc.1: using mode 640x480 pclk=23750000 href=1 vref=1
[ 4.283252] Console: switching to colour frame buffer device 80x30
[ 4.318488] tegradc tegradc.1: probed
[ 4.454118] tegradc tegradc.1: Unusuall display aspect ratio. You may encounter problems with base resolution
[ 4.504698] tegradc tegradc.1: Unusuall display aspect ratio. You may encounter problems with base resolution
[ 4.504711] tegradc tegradc.1: switching framebuffer to 800x480
[ 4.504721] tegradc tegradc.1: using mode 800x480 pclk=32000000 href=1 vref=1
[ 4.551847] tegradc tegradc.1: Unusuall display aspect ratio. You may encounter problems with base resolution
[ 4.551859] tegradc tegradc.1: switching framebuffer to 800x480
[ 4.551870] tegradc tegradc.1: using mode 800x480 pclk=32000000 href=1 vref=1
[ 4.674760] tegradc tegradc.1: display detected
[ 4.681391] tegra_uart.3: ttyHS3 at MMIO 0x70006300 (irq = 122) is a TEGRA_UART
[ 4.831137] Registered UART port ttyHS3
[ 4.836514] tegra_uart.1: ttyHS1 at MMIO 0x70006040 (irq = 69) is a TEGRA_UART
[ 4.991142] Registered UART port ttyHS1
[ 4.996734] tegra_uart.2: ttyHS2 at MMIO 0x70006200 (irq = 78) is a TEGRA_UART
[ 5.151136] Registered UART port ttyHS2
[ 5.156954] Initialized tegra uart driver
[ 5.168108] loop: module loaded
[ 5.173901] create_regulator: tps6591x_LDO_6: Failed to create debugfs directory
[ 5.184250] tegra-sata tegra-sata.0: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl TEGRA-SATA mode
[ 5.198017] tegra-sata tegra-sata.0: flags: 64bit ncq sntf pm led pio slum part apst
[ 5.209587] scsi0 : tegra-sata
[ 5.215649] ata1: SATA max UDMA/133 irq 55
[ 5.223268] Intel(R) Gigabit Ethernet Network Driver - version 5.2.17
[ 5.232565] Copyright (c) 2007-2015 Intel Corporation.
[ 5.281166] igb 0000:01:00.0: using Toradex OUI as default igb MAC
[ 5.343350] igb 0000:01:00.0: added PHC on eth0
[ 5.354003] igb 0000:01:00.0: Intel(R) Gigabit Ethernet Network Connection
[ 5.364043] igb 0000:01:00.0: eth0: (PCIe:2.5GT/s:Width x1)
[ 5.369655] igb 0000:01:00.0: eth0: MAC: 00:14:2d:00:00:00
[ 5.381536] igb 0000:01:00.0: eth0: PBA No: Unknown
[ 5.389440] igb 0000:01:00.0: LRO is disabled
[ 5.396753] igb 0000:01:00.0: Using MSI-X interrupts. 1 rx queue(s), 1 tx queue(s)
[ 5.407439] CAN device driver interface
[ 5.426209] mcp251x spi1.0: probed
[ 5.444215] mcp251x spi3.1: probed
[ 5.450492] PPP generic driver version 2.4.2
[ 5.457874] PPP Deflate Compression module registered
[ 5.465755] PPP BSD Compression module registered
[ 5.474207] PPP MPPE Compression module registered
[ 5.481910] NET: Registered protocol family 24
[ 5.490463] tun: Universal TUN/TAP device driver, 1.6
[ 5.498930] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 5.508984] usbcore: registered new interface driver asix
[ 5.517864] usbcore: registered new interface driver cdc_ether
[ 5.527131] usbcore: registered new interface driver cdc_subset
[ 5.536375] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 5.546251] tegra USB phy - inst[1] platform info:
[ 5.554231] port_otg: no
[ 5.559723] has_hostpc: yes
[ 5.565383] phy_interface: USB_PHY_INTF_UTMI
[ 5.572566] ata1: SATA link down (SStatus 0 SControl 300)
[ 5.580907] op_mode: TEGRA_USB_OPMODE_HOST
[ 5.587835] vbus_gpio: 233
[ 5.593276] vbus_gpio_inverted: 0
[ 5.599239] vbus_reg: NULL
[ 5.604555] hot_plug: enabled
[ 5.610064] remote_wakeup: enabled
[ 5.620977] tegra-ehci tegra-ehci.1: Tegra EHCI Host Controller
[ 5.629793] tegra-ehci tegra-ehci.1: new USB bus registered, assigned bus number 1
[ 5.661184] tegra-ehci tegra-ehci.1: irq 53, io mem 0x7d004000
[ 5.681151] tegra-ehci tegra-ehci.1: USB 2.0 started, EHCI 1.00
[ 5.689862] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 5.699363] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.709316] usb usb1: Product: Tegra EHCI Host Controller
[ 5.717506] usb usb1: Manufacturer: Linux 3.1.10-2.7.3+ga24d47d ehci_hcd
[ 5.727057] usb usb1: SerialNumber: tegra-ehci.1
[ 5.735320] hub 1-0:1.0: USB hub found
[ 5.741926] hub 1-0:1.0: 1 port detected
[ 5.749128] tegra USB phy - inst[2] platform info:
[ 5.756733] port_otg: no
[ 5.761999] has_hostpc: yes
[ 5.767436] phy_interface: USB_PHY_INTF_UTMI
[ 5.774350] op_mode: TEGRA_USB_OPMODE_HOST
[ 5.781145] vbus_gpio: -1
[ 5.786444] vbus_gpio_inverted: 0
[ 5.792384] vbus_reg: NULL
[ 5.797600] hot_plug: enabled
[ 5.803179] remote_wakeup: enabled
[ 5.810454] tegra-ehci tegra-ehci.2: Tegra EHCI Host Controller
[ 5.819095] tegra-ehci tegra-ehci.2: new USB bus registered, assigned bus number 2
[ 5.851189] tegra-ehci tegra-ehci.2: irq 129, io mem 0x7d008000
[ 5.871156] tegra-ehci tegra-ehci.2: USB 2.0 started, EHCI 1.00
[ 5.879777] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 5.889306] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.899311] usb usb2: Product: Tegra EHCI Host Controller
[ 5.907524] usb usb2: Manufacturer: Linux 3.1.10-2.7.3+ga24d47d ehci_hcd
[ 5.917121] usb usb2: SerialNumber: tegra-ehci.2
[ 5.925304] hub 2-0:1.0: USB hub found
[ 5.931917] hub 2-0:1.0: 1 port detected
[ 5.939289] Initializing USB Mass Storage driver...
[ 5.947211] usbcore: registered new interface driver usb-storage
[ 5.956053] USB Mass Storage support registered.
[ 5.963654] usbcore: registered new interface driver libusual
[ 5.972456] usbcore: registered new interface driver usbserial
[ 5.981087] USB Serial support registered for generic
[ 5.988983] usbcore: registered new interface driver usbserial_generic
[ 5.998331] usbserial: USB Serial Driver core
[ 6.005597] USB Serial support registered for pl2303
[ 6.013551] usbcore: registered new interface driver pl2303
[ 6.022043] pl2303: Prolific PL2303 USB to serial adaptor driver
[ 6.030995] Nvidia Tegra High-Speed USB SOC Device Controller driver (Apr 30, 2012)
[ 6.041953] tegra USB phy - inst[0] platform info:
[ 6.049836] port_otg: yes
[ 6.055499] has_hostpc: yes
[ 6.061365] phy_interface: USB_PHY_INTF_UTMI
[ 6.068731] op_mode: TEGRA_USB_OPMODE_DEVICE
[ 6.076144] vbus_pmu_irq: 0
[ 6.076155] vbus_gpio: -1
[ 6.076164] charging: disabled
[ 6.076173] remote_wakeup: disabled
[ 6.078961] tegra-udc tegra-udc.0: usb_bat_chg regulator not registered: USB charging will not be enabled
[ 6.079071] tegra-otg tegra-otg: SUSPEND --> HOST
[ 6.079343] tegra USB phy - inst[0] platform info:
[ 6.079356] port_otg: yes
[ 6.079365] has_hostpc: yes
[ 6.079374] phy_interface: USB_PHY_INTF_UTMI
[ 6.079384] op_mode: TEGRA_USB_OPMODE_HOST
[ 6.079394] vbus_gpio: 157
[ 6.079403] vbus_gpio_inverted: 0
[ 6.079412] vbus_reg: NULL
[ 6.079420] hot_plug: enabled
[ 6.079429] remote_wakeup: enabled
[ 6.080737] tegra-ehci tegra-ehci.0: Tegra EHCI Host Controller
[ 6.080829] tegra-ehci tegra-ehci.0: new USB bus registered, assigned bus number 3
[ 6.101223] tegra-ehci tegra-ehci.0: irq 52, io mem 0x7d000000
[ 6.121172] tegra-ehci tegra-ehci.0: USB 2.0 started, EHCI 1.00
[ 6.121312] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 6.121333] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 6.121350] usb usb3: Product: Tegra EHCI Host Controller
[ 6.121365] usb usb3: Manufacturer: Linux 3.1.10-2.7.3+ga24d47d ehci_hcd
[ 6.121381] usb usb3: SerialNumber: tegra-ehci.0
[ 6.122163] hub 3-0:1.0: USB hub found
[ 6.122198] hub 3-0:1.0: 1 port detected
[ 6.206537] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 6.206557] android_usb gadget: Number of LUNs=1
[ 6.206575] lun0: LUN: removable file: (no medium)
[ 6.207099] android_usb gadget: android_usb ready
[ 6.207119] tegra-udc: bind to driver android_usb
[ 6.322578] input: stmpe-ts as /devices/virtual/input/input0
[ 6.333758] using rtc device, m41t00, for alarms
[ 6.338376] rtc-ds1307 0-0068: rtc core: registered m41t00 as rtc0
[ 6.350659] tegra_rtc tegra_rtc: rtc core: registered tegra_rtc as rtc1
[ 6.360175] tegra_rtc tegra_rtc: Tegra internal Real Time Clock
[ 6.371673] rtc_tps6591x rtc_tps6591x.0: RTC Time : 1/1/2000 0:0:0
[ 6.382969] tps6591x 4-002d:
[ 6.382978] getting alarm time::
[ 6.394992] rtc_tps6591x rtc_tps6591x.0: RTC Time : 1/1/2000 0:0:0
[ 6.404558] rtc_tps6591x rtc_tps6591x.0: rtc core: registered rtc_tps6591x as rtc2
[ 6.420570] rtc_tps6591x rtc_tps6591x.0: RTC Time : 1/1/2000 0:0:0
[ 6.581211] i2c /dev entries driver
[ 6.589148] lirc_dev: IR Remote Control driver registered, major 242
[ 6.598903] IR NEC protocol handler initialized
[ 6.606713] IR RC5(x) protocol handler initialized
[ 6.614729] IR RC6 protocol handler initialized
[ 6.622463] IR JVC protocol handler initialized
[ 6.630117] IR Sony protocol handler initialized
[ 6.637831] IR RC5 (streamzap) protocol handler initialized
[ 6.646537] IR MCE Keyboard/mouse protocol handler initialized
[ 6.655488] IR LIRC bridge handler initialized
[ 6.663025] Linux video capture interface: v2.00
[ 6.671320] usbcore: registered new interface driver uvcvideo
[ 6.680207] USB Video Class driver (1.1.1)
[ 6.687845] trpc_sema_init: registered misc dev 10:55
[ 6.696334] trpc_node_register: Adding 'local' to node list
[ 6.706935] nvavp nvavp: allocated IOVM at ff00000 for AVP os
[ 6.725846] tegra_wdt tegra_wdt.0: tegra_wdt_probe done
[ 6.734657] tegra_wdt tegra_wdt.1: tegra_wdt_probe done
[ 6.743362] tegra_wdt tegra_wdt.2: tegra_wdt_probe done
[ 6.751778] Bluetooth: HCI UART driver ver 2.2
[ 6.759252] Bluetooth: HCI H4 protocol initialized
[ 6.767024] Bluetooth: HCILL protocol initialized
[ 6.774643] Bluetooth: BlueSleep Mode Driver Ver 1.1
[ 6.783287] cpuidle: using governor ladder
[ 6.790962] cpuidle: using governor menu
[ 6.797728] sdhci: Secure Digital Host Controller Interface driver
[ 6.806795] sdhci: Copyright(c) Pierre Ossman
[ 6.813977] sdhci-pltfm: SDHCI platform and OF driver helper
[ 6.822493] sdhci_tegra_init+ #####
[ 6.828997] sdhci-tegra sdhci-tegra.3: Error: tegra3 io dpd not supported for sdhci-tegra.3
[ 6.841357] mmc0: Invalid maximum block size, assuming 512 bytes
[ 6.850343] mmc0: no vmmc regulator found
[ 6.861988] mmc0: SDHCI controller on sdhci-tegra.3 [sdhci-tegra.3] using ADMA
[ 6.872587] Failed gpio lp0 enable for irq=395, error=-22
[ 6.881021] sdhci-tegra sdhci-tegra.2: SD card wake-up event registrationfailed with eroor: -22
[ 6.894328] mmc1: Invalid maximum block size, assuming 512 bytes
[ 6.903695] mmc1: no vmmc regulator found
[ 6.918095] mmc1: SDHCI controller on sdhci-tegra.2 [sdhci-tegra.2] using ADMA
[ 6.931030] Failed gpio lp0 enable for irq=453, error=-22
[ 6.941856] sdhci-tegra sdhci-tegra.0: SD card wake-up event registrationfailed with eroor: -22
[ 6.956122] sdhci-tegra sdhci-tegra.0: vddio_sdmmc regulator not found: -19.Assuming vddio_sdmmc is not required.
[ 6.975350] sdhci-tegra sdhci-tegra.0: vddio_sd_slot regulator not found: -19. Assuming vddio_sd_slot is not required.
[ 6.995442] sdhci-tegra sdhci-tegra.0: Error: tegra3 io dpd not supported for sdhci-tegra.0
[ 7.012302] mmc2: Invalid maximum block size, assuming 512 bytes
[ 7.019765] mmc2: no vmmc regulator found
[ 7.028557] mmc2: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA
[ 7.037339] sdhci_tegra_init- #####
[ 7.044009] tegra-se tegra-se: tegra_se_probe: complete
[ 7.049654] usbcore: registered new interface driver usbhid
[ 7.052886] [mmc]:mmc_decode_cid:123 cid.prv 0x3
[ 7.064271] [mmc]:mmc_read_ext_csd:297 ext_csd.sectors 0xe90000 prod_name H8G2d BOOT_MULTI 0x20
[ 7.067314] mmc0: new high speed DDR MMC card at address 0001
[ 7.067634] mmcblk0: mmc0:0001 H8G2d 7.28 GiB
[ 7.067784] mmcblk0boot0: mmc0:0001 H8G2d partition 1 4.00 MiB
[ 7.067937] mmcblk0boot1: mmc0:0001 H8G2d partition 2 4.00 MiB
[ 7.103498] usbhid: USB HID core driver
[ 7.105503] mmcblk0: p1 p2
[ 7.114871] stmpe-adc stmpe-adc.1: Initialized
[ 7.121438] mmcblk0boot1: unknown partition table
[ 7.134007] mmcblk0boot0: unknown partition table
[ 7.140429] [mmc]:mmc_rescan_try_freq:2119 mmc0: eMMC completed
[ 7.238954] mmc1: host does not support reading read-only switch. assuming write-enable.
[ 7.252306] mmc1: new high speed SDHC card at address 1234
[ 7.259545] mmcblk1: mmc1:1234 SA04G 3.69 GiB
[ 7.266827] mmcblk1: p1
[ 9.612602] usbcore: registered new interface driver snd-usb-audio
[ 9.635689] sgtl5000 4-000a: Failed to get supply 'VDDD': -19
[ 9.645665] print_constraints: 4-000a: 850 <--> 1600 mV at 1200 mV normal
[ 9.656736] sgtl5000 4-000a: Using internal LDO instead of VDDD
[ 9.667548] sgtl5000 4-000a: sgtl5000 revision 17
[ 9.680291] asoc: sgtl5000 <-> tegra30-i2s.2 mapping ok
[ 9.689721] asoc: dit-hifi <-> tegra30-spdif mapping ok
[ 9.700069] ALSA device list:
[ 9.706512] #0: apalis_t30-sgtl5000
[ 9.713471] #1: HDA NVIDIA Tegra at 0x70038000 irq 113
[ 9.722057] oprofile: hardware counters not available
[ 9.730298] oprofile: using timer interrupt.
[ 9.737944] GACT probability NOT on
[ 9.744600] Mirror/redirect action on
[ 9.751365] u32 classifier
[ 9.757027] Actions configured
[ 9.763303] Netfilter messages via NETLINK v0.30.
[ 9.770981] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 9.780644] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 9.790737] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 9.799934] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 9.808701] arp_tables: (C) 2002 David S. Miller
[ 9.816587] TCP cubic registered
[ 9.823150] NET: Registered protocol family 10
[ 9.832548] Mobile IPv6
[ 9.838138] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 9.847557] NET: Registered protocol family 17
[ 9.855105] NET: Registered protocol family 15
[ 9.862502] can: controller area network core (rev 20090105 abi 8)
[ 9.871898] NET: Registered protocol family 29
[ 9.879342] can: raw protocol (rev 20090105)
[ 9.886547] can: broadcast manager protocol (rev 20090105 t)
[ 9.895351] Bluetooth: RFCOMM TTY layer initialized
[ 9.903169] Bluetooth: RFCOMM socket layer initialized
[ 9.911192] Bluetooth: RFCOMM ver 1.11
[ 9.917721] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 9.925909] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 9.934882] 8021q: 802.1Q VLAN Support v1.8
[ 9.942017] Registering the dns_resolver key type
[ 9.949701] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[ 9.960458] Registering SWP/SWPB emulation handler
[ 9.986975] Disabling clocks left on by bootloader:
[ 9.994915] audio_2x
[ 10.000377] audio4_2x
[ 10.005968] audio3_2x
[ 10.011448] audio2_2x
[ 10.016817] audio1_2x
[ 10.022104] audio0_2x
[ 10.027271] audio
[ 10.031985] audio4
[ 10.036680] audio3
[ 10.041308] audio2
[ 10.045853] audio1
[ 10.050325] audio0
[ 10.054807] dsi2-fixed
[ 10.059522] dsi1-fixed
[ 10.064181] uarta
[ 10.068382] i2c2-fast
[ 10.072939] nor
[ 10.076877] bsev
[ 10.080772] bsea
[ 10.084632] fuse_burn
[ 10.088824] cclk_lp
[ 10.092835] pll_x_out0
[ 10.097042] pll_p_out2
[ 10.101211] pll_c_out1
[ 10.105290] pll_m_out1
[ 10.109911] CPU rate: 1300 MHz
[ 10.113625] tegra_fuse_program_init: no vdd_fuse. fuse write disabled
[ 10.120649] DVFS: Got RTC device name:rtc0
[ 10.125672] tegra_dvfs: vdd_cpu: stats above 1237 mV will be squashed
[ 10.133499] tegra3_dvfs: minimum cap.emc rate 800000000 requires 1300 mV
[ 10.140108] tegra dvfs: tegra sysfs cap interface is initialized
[ 10.147533] tegra_actmon.emc: Completed initialization (0)
[ 10.153774] tegra_actmon.avp: Completed initialization (0)
[ 10.160934] registered taskstats version 1
[ 10.166281] input: gpio-keys as /devices/platform/gpio-keys.0/input/input1
[ 10.174483] rtc-ds1307 0-0068: setting system clock to 2000-01-01 01:02:36 UTC (946688556)
[ 10.191578] kjournald starting. Commit interval 5 seconds
[ 10.197952] EXT3-fs (mmcblk0p2): using internal journal
[ 10.204019] EXT3-fs (mmcblk0p2): mounted filesystem with writeback data mode
[ 10.211994] VFS: Mounted root (ext3 filesystem) on device 179:2.
[ 10.220787] devtmpfs: mounted
[ 10.321540] systemd[1]: System time before build time, advancing clock.
[ 10.591394] systemd[1]: systemd 230 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS -ACL -XZ +LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD +IDN)
[ 10.614593] systemd[1]: Detected architecture arm.
Welcome to The Ångström Distribution v2016.12!
BR
