I am making changes to use a 24 bits LCD display (800x480) on a Colibri iMX6 with console-trdx-image.
My dts file is based on imx6dl-colibri-eval-v3.dts.
I added
&lcd {
default_ifmt = "RGB24";
&mxcfb1 {
interface_pix_fmt = "RGB24";
mode_str ="800x480M@60";
default_bpp = <32>;
&pinctrl_ipu1_lcd {
fsl,pins = <
MX6QDL_PAD_DI0_DISP_CLK__IPU1_DI0_DISP_CLK 0xa1
MX6QDL_PAD_DI0_PIN15__IPU1_DI0_PIN15 0xa1
MX6QDL_PAD_DI0_PIN2__IPU1_DI0_PIN02 0xa1
MX6QDL_PAD_DI0_PIN3__IPU1_DI0_PIN03 0xa1
MX6QDL_PAD_DISP0_DAT0__IPU1_DISP0_DATA00 0xa1
MX6QDL_PAD_DISP0_DAT1__IPU1_DISP0_DATA01 0xa1
MX6QDL_PAD_DISP0_DAT2__IPU1_DISP0_DATA02 0xa1
MX6QDL_PAD_DISP0_DAT3__IPU1_DISP0_DATA03 0xa1
MX6QDL_PAD_DISP0_DAT4__IPU1_DISP0_DATA04 0xa1
MX6QDL_PAD_DISP0_DAT5__IPU1_DISP0_DATA05 0xa1
MX6QDL_PAD_DISP0_DAT6__IPU1_DISP0_DATA06 0xa1
MX6QDL_PAD_DISP0_DAT7__IPU1_DISP0_DATA07 0xa1
MX6QDL_PAD_DISP0_DAT8__IPU1_DISP0_DATA08 0xa1
MX6QDL_PAD_DISP0_DAT9__IPU1_DISP0_DATA09 0xa1
MX6QDL_PAD_DISP0_DAT10__IPU1_DISP0_DATA10 0xa1
MX6QDL_PAD_DISP0_DAT11__IPU1_DISP0_DATA11 0xa1
MX6QDL_PAD_DISP0_DAT12__IPU1_DISP0_DATA12 0xa1
MX6QDL_PAD_DISP0_DAT13__IPU1_DISP0_DATA13 0xa1
MX6QDL_PAD_DISP0_DAT14__IPU1_DISP0_DATA14 0xa1
MX6QDL_PAD_DISP0_DAT15__IPU1_DISP0_DATA15 0xa1
MX6QDL_PAD_DISP0_DAT16__IPU1_DISP0_DATA16 0xa1
MX6QDL_PAD_DISP0_DAT17__IPU1_DISP0_DATA17 0xa1
MX6QDL_PAD_DISP0_DAT18__IPU1_DISP0_DATA18 0xa1
MX6QDL_PAD_DISP0_DAT19__IPU1_DISP0_DATA19 0xa1
MX6QDL_PAD_DISP0_DAT20__IPU1_DISP0_DATA20 0xa1
MX6QDL_PAD_DISP0_DAT21__IPU1_DISP0_DATA21 0xa1
MX6QDL_PAD_DISP0_DAT22__IPU1_DISP0_DATA22 0xa1
MX6QDL_PAD_DISP0_DAT23__IPU1_DISP0_DATA23 0xa1
&lcdif {
display = <&display0>;
display0: display {
bits-per-pixel = <24>;
bus-width = <24>;
display-timings {
native-mode = <&timing_wvga>;
/* WVGA Timing, LCD 800x480 7" */
timing_wvga: 800x480 {
clock-frequency = <33260000>;
hactive = <800>;
vactive = <480>;
hback-porch = <88>;
hfront-porch = <40>;
vback-porch = <32>;
vfront-porch = <13>;
hsync-len = <48>;
vsync-len = <3>;
de-active = <1>;
hsync-active = <0>;
vsync-active = <0>;
pixelclk-active = <0>;
In u-boot I have cleared vidargs as requested at the end of Display Output, Resolution and Timings (Linux) | Toradex Developer Center
When I restart the module, the toradex logo is displayed a short time, and after blank screen when linux kernel is started apparently. The display seem to work only in u-boot.
Linux seem to not known the parameters in the dts file:
colibri-imx6 login: root
Last login: Wed Mar 29 17:31:54 UTC 2017 on ttymxc0
root@colibri-imx6:~# fbset
mode "640x480-60"
# D: 25.175 MHz, H: 31.469 kHz, V: 59.940 Hz
geometry 640 480 640 480 16
timings 39722 48 16 33 10 96 2
accel false
rgba 5/11,6/5,5/0,0/0
endmode
If I try to change the resolution, I can see that the display timming from the dts are not taken:
root@colibri-imx6:~# fbset -xres 800 -yres 480
[ 677.762157] mxc_sdc_fb fb@1: 800x480 h_sync,r,l: 96,16,48 v_sync,l,u: 2,10,33 pixclock=25174000 Hz
root@colibri-imx6:~# cat /sys/class/graphics/fb0/mode
U:800x480p-49
What is wrong? Why my re definition of lcdif seem to not overload the original definition?
I believe that I need 32bpp frame buffer for Qt but the lcd interface use 24 bits. Does I choosen the right values into lcd and mxcfb1 blocks in the dts file?
Curriously, I don’t find in the dts* files (included into imx6dl-colibri-eval-v3.dts) any display-timings block for your EDT 7". Where it is?
I searched in google a definition for fbmem parameter in u-boot and I found nothing, only many cases of use without explanation. Does somebody have a link for definition?
Regards
