Hello!
To ensure that the libwebsockets library is correctly included in your SDK and that you can use its APIs, please follow these steps:
Verify Yocto Configuration:
- Double-check your
local.conffile to ensure it includes the correct entries:IMAGE_INSTALL:append = " libwebsockets" TOOLCHAIN_TARGET_TASK:append = " libwebsockets" SDKIMAGE_FEATURES:append = " libwebsockets" - Look out for any typos or syntax errors in these lines.
- Double-check your
Rebuild the SDK:
- Once you’ve confirmed the configuration, rebuild the SDK with the command:
bitbake <your-image-name> -c populate_sdk - This will regenerate the SDK with the specified packages.
Install the SDK:
- After building, install the SDK by running the generated script found in
oe-core/deploy/sdk/. - Source the environment setup script provided by the SDK to set up the cross-compilation environment.
Check for libwebsockets in the SDK:
- Verify that the
libwebsocketsheaders and libraries are present in the SDK’s sysroot. Check the include directory forlibwebsockets.hand the lib directory for the corresponding library files.
- Verify that the
Compile Your Application:
- Ensure your application’s build system (e.g., Makefile, CMake) is configured to include the libwebsockets headers and link against its libraries. This typically involves adding
-Iand-Lflags to the compiler and linker commands, respectively. - For example, you might need to add:
-I<path-to-sdk>/sysroots/<target>/usr/include -L<path-to-sdk>/sysroots/<target>/usr/lib -lwebsockets
Troubleshoot Compilation Issues:
- If issues persist, check the compiler and linker output for any missing paths or unresolved symbols related to libwebsockets.
- Ensure that the environment variables set by the SDK’s environment script are correctly applied in your build process.
By following these steps, you should be able to confirm whether libwebsockets is properly included in your SDK and resolve any issues with using its APIs in your application.
