I need to cross compile python2 packages using openembedded sdk. The sdk
resulting package contains only python 3.5.3 (in older version it contains
python 2.7.3 as well).
# ls -l sysroots/x86_64-angstromsdk-linux/usr/bin/python*
lrwxrwxrwx 1 root root 9 Oct 11 21:39 python3 -> python3.5*
-rwxr-xr-x 1 root root 267 Oct 11 21:39 python3.5*
lrwxrwxrwx 1 root root 17 Oct 11 21:39 python3.5-config -> python3.5m-config*
-rwxr-xr-x 2 root root 15K Oct 11 21:39 python3.5m*
-rwxr-xr-x 1 root root 3.3K Oct 11 21:39 python3.5m-config*
-rwxr-xr-x 2 root root 15K Oct 11 21:39 python3.5.real*
lrwxrwxrwx 1 root root 16 Oct 11 21:39 python3-config -> python3.5-config*__
Is there a way to add also this native python version to my sdk?
I’m using toradex-bsp-platform at tag “Colibri-iMX6_LXDE-Image_2.8b3.111-20180627”.
I assume you build the SDK by using the ‘bitbake -c populate_sdk ‘’‘image_recipe’’’ ’ task.
I expect the following to add python2 to the host tools in the SDK. Add to either the the image recipe or local.conf:
Please have a look here for the relevant Yocto documentation.
Alternatively have a look at this bbappend:
meta-freescale/recipes-core/packagegroup/nativesdk-packagegroup-sdk-host.bbappend
This will add to all SDK’s build without the need to add something to the image recipe.
lrwxrwxrwx 1 root root 7 ott 15 21:53 python -> python2
lrwxrwxrwx 1 root root 9 ott 15 21:53 python2 -> python2.7
-rwxr-xr-x 1 root root 297 ott 15 21:52 python2.7
-rwxr-xr-x 1 root root 1739 ott 15 21:52 python2.7-config
-rwxr-xr-x 1 root root 10240 ott 15 21:53 python2.7.real
lrwxrwxrwx 1 root root 16 ott 15 21:53 python2-config -> python2.7-config
lrwxrwxrwx 1 root root 14 ott 15 21:53 python-config -> python2-config
But the sdk bash script exit with error, it only unpacks the sysroots and then stalls:
# ./angstrom-glibc-x86_64-armv7at2hf-neon-v2017.12-toolchain.sh -d 4.9
Angstrom SDK installer version nodistro.0
You are about to install the SDK to "/opt/toradex_sdk/imx6/4.9". Proceed[Y/n]?
Extracting SDK.........................................................................................................done
Setting it up...ls: cannot access '/opt/toradex_sdk/imx6/4.9/environment-setup-*': No such file or directory
