Please guide for adding Hindi\ Devanagari fonts to WinCE6 for VF50
Dear @Madhav
I didn’t test it, but the following steps should do the job:
- Look for the font you want to use in TTF format
(e.g. I found a free Devnagari font here:
Kruti Dev 714 Normal ) - Copy the *.ttf font file(s) to the Colibri folder
\Flashdisk\System\Fonts\. - For each font, add a registry entry in
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\FontLink\SystemLink]. Use the following article as an example:
How to install additional fonts - Save the registry
- Reboot
- After each reboot, you have to execute some code, which calls the function
AddFontResource()for each new font.
Details about this function can be found in the Microsoft documentation:
AddFontResource
Regards, Andy
For information watch this video and Read this Article
Video - https://youtu.be/KcJG5Swi77w
Article - Kruti Dev Hindi Typing
It’s very Simple I explain in my Article check it.
Article - Manglish Typing
Anu Script Telugu Typing Software for Windows if you need to check this
Link - anu script telugu typing software free download for windows 10
Thanks for your Input.
