I am developing an Yocto Linux OpenEmbedded application by using Apalis.
I am facing an issue for build SDK. (software development kit)
I want to include “grpcio-tools” python module into my SDK, so I added this in my recipe.
[upload|+pAH3A2Md9vcKVvaw1z+IFxZD40=]
The SDK is bitbake successfully.
Below are my findings:
After SDK is installed, and there are two folders, “aarch64-tdx-linux” , “x86_64-tdxsdk-linux”
[upload|xvI+2RhyX6AXMwh0em9o7ssTXMw=]
I realized that the grpc_tools only installed in aarch64-tdx-linux/usr/lib/python3.8/site-packages
[upload|YmQ12lDfYdVx6h7eFNTOl5zWUHU=]
And it doesn’t install in x86_64-tdx-linux/usr/lib/python3.8/site-packages
[upload|Bz6g0n5dUZVRFlcTaQSzQBWUBJs=]
And it cause a problem, “ModuleNotFoundError” when I try to execute it in my SDK.
[upload|pOdBkgm+rcZ+cvteuvV0S+9VLGs=]
Question :
What should I do in recipe to make it installed inside both folders ?
My application is Aarch64. So my recipe is set to Aarch64.
Now I use same recipe to build image and SDK.
For SDK, I am running on x86_64 Ubuntu machine.
Hi @tanchunhau , you can also add TOOLCHAIN_TARGET_TASK_append = " python3-grpcio-tools" to local.conf.
HI @benjamin.tx
after added TOOLCHAIN_TARGET_TASK_append = " python3-grpcio-tools".
and in my another .bb file,
I want to invoke it:
DEPENDS += " python3-grpcio-tools"
do_compile(){
python3 -m grpc_tools.protoc -I ${S} --python_out=. --grpc_python_out=. ${S}/tests/rcu_ser.proto
And the module is not found in my OE-Build environment.
Do you know how to invoke the grpc_tools.protoc module for my do_compile ?
Hi @tanchunhau , it seems to me that gRPC is not installed on your PC. Do you install it according to this page?
Hi @benjamin.tx ,
I din’t install it in my pc, I am trying to make it exists in my OE-Build toolchain (so it is independent from my PC), do I need to install it in my PC ?
Hi @tanchunhau , then you may try to add HOSTTOOLS += ' python3-grpcio-tools' to local.conf.
hi @benjamin.tx , it show me this message after bitbake:
ERROR : The follwoing required tools (as speficied by HOSTTOOLS) appear to be unavailable in PATH, please install them in order to proceed:
I will try to debug later, thank you very much
Hi @tanchunhau , I just modify HOSTTOOLS` and get the same error. You can try to install grpcio-tools directly on your PC.
Hi @benjamin.tx
I added
inherit python3native
DEPENDS += " python3-grpcio-tools-native"
and it works !
@tanchunhau . Thanks for your sharing.
