Based on the context provided, it seems you are trying to ensure that your custom device tree binary (DTB) is included in the deploy directory when building your Yocto image for the IMX8MP board. Here are some general steps you can follow to achieve this:
Ensure the Device Tree is Built: Since you’ve already modified the Makefile to include your custom DTB, ensure that your changes are correctly integrated into the kernel build process. This typically involves adding your DTB to the
dtb-yvariable in the Makefile. -
Modify the Kernel Recipe: You may need to modify the kernel recipe to ensure that your custom DTB is included in the deploy directory. This can be done by appending your DTB to the
KERNEL_DEVICETREEvariable in your kernel recipe or a bbappend file. For example:KERNEL_DEVICETREE += "freescale/your-custom-dtb.dtb" -
Check the Image Recipe: Ensure that the image recipe (e.g.,
tdx-reference-minimal-image.bb) is set up to include the kernel and its associated DTBs. This is usually handled by default, but it’s good to verify. -
Verify the Deployment: After building the image with
bitbake tdx-reference-minimal-image, check thedeploydirectory (usually undertmp/deploy/images/<machine>/) to see if your DTB is present.
If these steps do not resolve the issue, it may be necessary to review the specific Yocto layers and configurations used in your build to ensure that there are no additional customizations or overrides affecting the deployment of DTBs.
How to include Device Tree and Linux kernel in Yocto build?.
