when we connect to WEC2013 via usb otg cable it shown in devices as “Generic Serial (PROTOTYPE–Remember to change idVendor)” but this connection not shown in windows mobile device center. Due to this issue colibri disk(flashDisk) is not display in windows explorer.To access flashdisk in our system how we connect them?
Dear @kshah
WEC2013 does not support Windows Mobile Device Center (WMDC), which is required to simply see the Colibri flash disk on the PC as you expect.
You can configure the USB function driver to act as a mass storage device. The developer page article USB Function Driver (WinCE) describes the details how to achieve this.
Please note that the flashdisk cannot be shared between the WEC2013 system and the PC. This means, while the USB cable is connected between the USB OTG port and the PC, the /Flashdisk/
folder and subfolders are not accessible for any Windows CE application.
If you need to share files while the USB cable is connected, one option is to use an Ethernet connection - either through regular Ethernet, or through USBRNDIS over the USB OTG cable.
Regards, Andy
Thank you for your solution.
We go through your answer to get files while the USB is connected but can’t accessible through regular ethernet.
kindly share any links or literature.
Dear @kshah
I’m not sure whether I understood your comment correctly.
For seeing the /Flashdisk/
folder as a thumb drive from the PC, simply follow the instructions in the article USB Function Driver (WinCE).
Regards, Andy
