The display interface appears common. 40-pin RGB24 TFT LCD.
I am trying trial an error vidargs using snippets I find on developer.toradex.com
I am using the Qt E-Bike Demo image. Maybe this will not work at resolutions below 640x480?
Steps Taken
- Disconnect VGA port that worked
with E-Bike Demo. I tested down to 640x480
(setenv vidargs
video='mxsfb:640x480M-16@60)
- With power-off, connect AZ ATM0430D12M, 480 x 272, RGB24 to X34 Unified TFT Interface
- U-boot using following vidargs:
setenv vidargs video='mxcfb0:480x272M-16@60,if=RGB24’
Kernel starts according to u-boot terminal
Display remains black, no flickering, nothing.
- Is frame buffer name correct?
- bpp ?
- Refresh freq?
Any tips or suggestions are much appreciated.
Thanks in advance,
-Ed
References:
Hi @embeddedEd
I quickly checked the datasheet of the display and it looks like they don’t exactly use the Unified Display Interface but a slightly changed version. I guess you would need some kind of converter circuit to make it work with our Evaluation Board.
See: https://docs.toradex.com/100069-iris-datasheet.pdf Section 3.7.2
And https://www.azdisplays.com/PDF/ATM0430D12M.pdf Section 2
The iMX6ULL has a different naming for the video device:
setenv vidargs video='mxsfb:480x272M-16@60'
See Display Output, Resolution and Timings (Linux) | Toradex Developer Center.
Maybe you would also have to add the resolution to the devicetree file, because it is unusual. We explain that in the same article.
I think the Qt application should be shown on a display with this resolution. It normally scales pretty well.
Stefan
@stefan_e.tx Thank you for the great info!
I put the Unified Display Interface versus AZ ATM0430D12M pin-out in a spreadsheet in side-by-side columns and I understand what you mean.
I may just purchase one of 480 x 272 displays listed on your Supported Displays page to save time from having to create a generic RGB adapter adapter board.
Thank you for pointing out the naming used by the iMX6ULL and timing / devicetree info.
At this point I mainly want to see how the Qt E-Bike demo scales down to 480 x 272 and investigate if demo source is available and if UI could be tweaked for a mockup prototype.
I am trying to figure out if Linux can handle generation of low-latency streaming audio that depends on an analog input and updates a UI widget such as a meter or signal-level bar. Similar to a geiger counter or a metal detector device.
Thanks again!
