How SD Card pull-up resistores handle in Torizon OS SD-Card Drives?
Hello All,
We are using Verdin iMX8MP SOM and build our custom reference minimal Torizon OS. I want to check and confirm whether SD card pull-up regsiter properly handled in SD card driver firmware?
Because the below document said when SD card remove the respective pull-up resistors need to be disabled in FW.
Is this taken care by SD card driver firmware internally, please confirm?
Thanks in advanced..!!
SD Card Pull-Up Resistor Configuration on Verdin iMX8M Plus
Hardware Configuration
The Verdin iMX8M Plus includes internal pull-up resistors on the SD card interface (1). According to the datasheet, for the Always Compatible SD Card Interface (USDHC2), the pull-up resistors are enabled on the SoC level for the following signals (1):
  • SD_1_CMD (USDHC2_CMD) - Command line
  • SD_1_D0 through SD_1_D3 (USDHC2_DATA0-3) - Data lines
  • SD_1_CD# (USDHC2_CD_B) - Card Detect
Driver Implementation
The SD/MMC driver automatically handles card insertion and removal (2). When an SD card is inserted, it appears as a /dev/mmcblk<id> block device, and the kernel exports card partitions with appendix p<x> (2).
You can verify proper SD card detection by checking system logs (2):
# dmesg | egrep "(sdhci|mmc)"
(2)
Or check for system interrupts triggered upon SD card insertion (2):
# cat /proc/interrupts | egrep "(mmc|cd)"
(2)
Pull-Up Resistor Management
The documentation states that no external pull-up resistors are required on the carrier board as there are pull-up resistors on the module (1). The SD interface supports both 3.3V and 1.8V IO voltage levels for UHS-I compatibility (1).
Verification Commands
To verify your SD card is properly detected and configured, you can use (2):
# ls -l /dev/verdin-sd*
(2)
This will show the corresponding /dev/mmcblk<id> block device when a card is inserted (2).
Conclusion
Based on the Toradex documentation, the SD card driver firmware does handle pull-up resistor configuration internally. The hardware design includes on-module pull-up resistors, and the driver manages the card detection and interface configuration automatically when cards are inserted or removed.
