Hi. I’m new. I’m looking for an easy way to read data using rcm. my colibri t30 Board has damaged emmc memory and I would like to try reading the saved data using rcm. is there a good way to do this?
HI @Mihail
Could you provide the version of the hardware (including carrier board) and software of your module?
Recovery mode can be used to load U-Boot in Ram and then read the contents of eMMC. For reading the contents you need to stop in U-Boot and you use this method to mount eMMC Flash as a disk.
