Today I have compiled an image with yocto. My question is simple. How to assemble the EasyInstaller files. I have seen that there is a json database. I could change the name of the rootfs and bootfs files but I do not know if it’s enough because below it informs up the uncompressed size of those files. What do I have to do to have my customized EasyInstaller image? Thank you.
thanks for your reply. My question is simple. I use Apalis TK1 2GB v1.2A. I want to add my application and some files to rootfs. I have observed that there is a json database. Should I modify the size value of rootfs.tar.xz? Can you round the value? tanks
