i need to use PWM for LED dimming. my question is, how can i let PWM be active during suspend mode ?
thank you
thank you
hi zanam
You should switch the PWM to a clock source (for example 32kHz Oscillator), which is working in low power mode. Then you must ensure that this oscillator is working in low power mode.
