Hello, how can I install “libcrypto++6 (or libcrypto++8)” with yocto? Normally, I would add debian source.list after installation and install it with apt, but it causes many problems. Likewise, I want to install “default-jre-headless”. I use Kirkstone. I was adding those that do not have such recipes from the source code, but the source code of these is difficult to find and I did not know how to make the recipes. Below is a recipe I found for libcrypto++6, but it doesn’t work.
SUMMARY = "A free C++ class library of cryptographic schemes"
HOMEPAGE = "http://www.cryptopp.com/wiki/Main_Page"
BUGTRACKER = "http://sourceforge.net/apps/trac/cryptopp/"
SECTION = "libs"
LICENSE = "BSL-1.0"
LIC_FILES_CHKSUM = "file://License.txt;md5=deb6d182b0f7f8a866c42941b9f014c4"
BBCLASSEXTEND = "native nativesdk"
PR = "r1"
PVSHORT = "${@'${PV}'.replace('.','')}"
SRC_URI = " \
https://sourceforge.net/projects/cryptopp/files/cryptopp/5.6.4/cryptopp564.zip;subdir=libcryptopp-${PV} \
file://0001-Fix-cross-compilation.patch \
SRC_URI[md5sum] = "4ee7e5cdd4a45a14756c169eaf2a77fc"
SRC_URI[sha256sum] = "be430377b05c15971d5ccb6e44b4d95470f561024ed6d701fe3da3a188c84ad7"
inherit autotools-brokensep pkgconfig
EXTRA_OECONF = "--libdir=${base_libdir}"
#we want tegrarcm binary to run on a 32-bit architecture, on x86_64 this requires the 32-bit compatibility libs
EXTRA_OEMAKE_class-native = "CC='${CC} -m32' CXX='${CXX} -m32'"
do_compile() {
sed -i -e 's/^CXXFLAGS/#CXXFLAGS/' GNUmakefile
export CXXFLAGS="${CXXFLAGS} -DNDEBUG -fPIC"
oe_runmake -f GNUmakefile
oe_runmake libcryptopp.a
do_install:prepend() {
export PREFIX=${prefix}
do_install:append() {
if [ -f "${D}/usr/lib/libcryptopp.so" ] && [ ! -e "${D}/usr/lib/libcryptopp.so.${PV}" ]
then
mv ${D}/usr/lib/libcryptopp.so ${D}/usr/lib/libcryptopp.so.${PV}
ln -fs libcryptopp.so.${PV} ${D}/usr/lib/libcryptopp.so.5
fi
