How can I chance dns configuration and set static Ip address on colibri imx6dl v1.0A
What OS and what version of that OS are you using?
OS: angstrom v2014.12 - Kernel 3.10.17
IMG: colibri_iMX6_LinuxImage2.4_20150518
The Toradex Demo Images use connman as their network management application.
By default the module uses dhcp to get its network configuration.
To set a static IP address and nameservers:
see the help text
list the available services
set IP/mask/default gateway
set nameserver(s)
connmanctl help
connmanctl services
connmanctl config ethernet_00142d259a48_cable --ipv4 manual 192.168.10.2 255.255.255.0 192.168.10.1
connmanctl config ethernet_00142d259a48_cable --nameservers 8.8.8.8
See also the developer website.
Thank you so much …
